01-03-2008 10:47 AM
Had the Drivers Door on this morning, got some mods to do to the Inside Door Panel to fit, But the Door Opened and Closed perfectly. I ran the shrinking disk for about 5 hours on the Drivers Quarter, my hands are still torqueing to the right. I was pleased with my results, but there were still a few spots I could not get to come flush. The bodyline down the center of the panel gave me fits, I think it will require a tad bit of grinding and filler to set it just right. I got a few pictures, one shows the Semi Completed Quarter(at least as far as I'm concerned
), the other shows the side ground effects. Note the 6.4 Inches I took from the car now needs to come from the ground effects.
Short Post tonight, Tony Stewarts racing Outlaws in Fort Wayne, at the Colisium tonight.
Anyone got some suggestions on the Ground Effects? There Flexible, Urethane?
Thanks for any Any Help, Happy New Year!
__________________
Joe Andrews
Dr. Feelgood
Brian
3400 SFI V6, 4T60e
Looks really slick.
As a side note, I had a minor role in the Northstar GP build. I brought four cylinder heads from New Jersey to Madison, WI. It's a car I really want to see in person.
Mr. Orange.
Why the 57? It sounds good though. (was thinking 34+28 but that's 62!)
Crazyness! keep up the good work!
I'm not up to date on the V8 engines, but I think the WS6 that is going in this is a 350, which is 5.7L.
If the firebird is 93 to 97 its a 350 LT1 if it is 98 to 02 its a LS1 which is like 346 cubic inch but they still call it a 5.7L
68 El camino 454 speed muncie 3.90 posi 12 bolt,
80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
60 Impala 2 door hardtop L79-327 T56 4.11 posi.
83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
91 Z34 now has a hm284. and belly pan in the works
I'm a fan of the original style lettering for the decals. The other is the z71 truck style, so I immediately think of "Silverado" instead of "Lumina".
86euro I'm a fan of the original style lettering for the decals. The other is the z71 truck style, so I immediately think of "Silverado" instead of "Lumina".
I agree, I like the original to but I don't want the stripe around the middle of the car. When you remove the stripe from the original it looks Funny and Small, that's why I chose the Newer Style.
latemodelnewbee If the firebird is 93 to 97 its a 350 LT1 if it is 98 to 02 its a LS1 which is like 346 cubic inch but they still call it a 5.7L
Correct, it's a 1998 Formula T/A, LS1 automatic with 340 HP.
IsaacHayes Why the 57? It sounds good though. (was thinking 34+28 but that's 62!)
Thanks Buddy, Z57 because the 3.4 DOHC is gone and has been replaced by the LS1 5.7 litre, plus Heinz 57 steak sauce is a blend of a lot of Ingredients!
DEI37 Looks really slick.
That's one cool ride, I'm not a Caddy fan but the Car turned out Beautiful, I'd Love to See it in Person as well.
I wired up all of the Lights on the Car as well, really very simple and Both cars use the newer style bulb. Color codes were different on the wires, but an OHM meter straightened that out.
Sorry I took so long to reply, a lot of what I'm working on is repetitive, I've shown the drivers side being done and now it's the passenger side being completed. In a couple of weeks I should be doing the Inner Fenders, I'll post more pics when I reach that point.
Thanks for the Great comments you guys, it Helps keep me motivated.
Joe
