N/A all the way
Eric
04-09-2008 08:56 PM
Actually it would be better if you just whipped up a piece of flat iron and weld it to the corner to complete the mount pad then drill and tap it. The RWD 3.4L poses the same problem in the Fiero swap at least the engine I had did, where the corner of the opposite starter mount pad was angled at the end. I didn't even bother welding on the block. I just drilled the inboard hole, ground a flat spot in the angled area so that I could drill into it, then mounted the starter head on the block and used the outboard bolt passage to center and target the drill bit. I was careful not to over torque the outboard bolt since that area of the starter had no compression surface. I never had a problem with it. I used the actual starter nose as a jig after removing it from the starter assembly.
I don't believe you'll have a problem with the manifold being reversed after giving it some thought. The water is still being forced into the block and up into the cylinder head and then towards the exit. It will rearrange the thermal character as far as heat distribution but there is nothing keeping the coolant at the rear of the cylinder head from flowing forward as the water exits the intake outlet. You could use a cooler thermostat for added piece of mind or remove it all together to increase overall flow through the system. More convincingly the twin turbo chevette has had main cap problems instead of head gasket and overheat problems.
Iron Head Enthusiast
Well the head gaskets should have water passage holes that direct water flow. They could be moved around depending on application.
In a RWD vehicle you want water to come in the front of the block and head to the back of the block and then up to the head and out the intake.
Making it work
Uhhh I think you have your water flow mixed up. Coolant does not go from one side to the other. If comes into the pump from the lower rad hose and the heater hose (if the t-stat is open) it then is forced into the block through the holes in the front. The water flows to the back of the block and the up into the heads and out the 2 passages you see in the intake manifold where it meets at the thermostat housing and into the upper rad hose, there is also the alternate path through the heater hose to the heater core. This is why the head gasket water passage holes are different and have directions on what way they face. The holes in the water passages are key to make water flow the right way.
Making it work
betterthanyou
Not confused. Whats going to get coolant to the back of the heads with the manifolds in the pics? The 3x00 intake has the 2 water ports furthest from the t-stat blocked off. The entire back of the engine is going to get less flow.
This means the coolant is going to stay in the front of the block in a RWD configuration, correct? It's not going to circulate properly.
N/A all the way
I can understand that there's coolant passages at both ends of the heads so that you can swap heads from side to side, but why isn't there a passage at the front of the LIM? I guess I would be answering my own question by saying that I think it's b/c by blocking it off, any coolant entered at the front of the head from the block would be forced to run across the head and then into the intake and thermostat. Pretty much coolant can enter anywhere into the head from the block passages (front, middle, rear) and then across the head towards the back. It's like the block are the arteries and the head are the veins, b/c blood can flow in different paths but long it get from point A to B. But I wonder if by blocking the rear passage, there would be some stagnate coolant at the back, but lots of flow in the front of the head. I know I'm the one that's started the off topic but it's been bothering me. Plus, how are the RWD block, heads, and intakes designed for coolant passages. I probably should just sleep on it.
N/A all the way
The thing is ForcedFirebird, to save money as well as space in my chevette, I want to take advance of the crank pulley/damper by moving the engine back and down clearing the sway bar. Wouldn't be able to with the RWD front setup, plus to change over to that setup is going to cost money I need for other stuff.
Wiz85
hahaha, Like a big fat bottle of nitrous.. Do the custom intake, they actualy work pretty good, being how I was told many times that it would never work.. If you want Pm me and Ill give you info on the port opening size for powerband range, ive already played around making a couple of those aluminum intakes fitting 4bbls, and if the port openings are to wide ur powerband goes threw the roof.. (Not good for street use)
