Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
Thread: ? about building a 94 RWD 3.4
    ...he must have maintained the DIS? I bet that's interesting.
    Actually, it wouldn't be a bad thing to have a custom-built intake. The Edelbrock on the transverse mounted motor puts the carb basically sideways. Not bad until you go balls-out into a hard left and slosh all the fuel to the outside of the right side (would-be front) bowl.
    I could get behind that idea if I could work out the ignition system.
  3. #12
    does any one have advice about the hump in the intake runners of the 3.4 camaro heads
  4. #13
    Jan 2007
    Ft Lauderdale, FL
    4,215
    Quote Originally Posted by 3400CaMaRo View Post
    What hump? On the inside of the intake ports of the heads?
  5. #14
  6. #15
    That "shark fin" should stay in place. It supposedly helps the heads to flow a bit better. It's OK to smooth them out and polish them, but don't remove them.
  7. #16
    Jan 2007
    Ft Lauderdale, FL
    4,215
    Make them into a shark fin shape.
  8. #17
    i finished porting mine today no shark fin at all they flowed 127 cfm on the intake and 112cfm on the exhaust at .450" lift then they started to flow less above .450" what do they flow stock i couldnt bench them before hand
  9. #18
    Jan 2007
    Ft Lauderdale, FL
    4,215
    Does this help?
  10. #19
    Everything I've read about those heads suggests they flow best with those fins intact.
  11. #20
    Jan 2007
    Ft Lauderdale, FL
    4,215
    Quote Originally Posted by taijiguy View Post
    Exactly. They now flow only as good, or worse, than stock after being ported.
