03-09-2009, 07:19 PM
#101
sweet-thanks for the info, man! you're dynoing it on fri or sat?
1991 chevrolet lumina euro-2 door-3.1-alum. head-4 speed automatic-158k on it.
03-09-2009 07:19 PM
03-09-2009, 07:29 PM
#102
saturday goal is 475-500 or bust
03-09-2009, 10:15 PM
#103
sweet! i cant wait! you make 500 and ill send you a cookie. i know its not much, buti figure the reward of 500hp is reward enough :P
03-09-2009, 10:16 PM
#104
28 psi-28 people voted lol what a coinkeedink
03-10-2009, 08:32 PM
#105
might have aposssible hiccup with my new turbo after installing it ont he car it has some sight drag on the wheels.
well my friend that works on gn's hooked me up with a rebuilt chra, so if wirse comes to worse i will swap in the new chra tom after i take the 60-1 apart to see whats going on
03-10-2009, 10:33 PM
#106
Humm, Quad Cam Goodness!!
Love the thread
But um about that last post, maybe I am an idiot but huh? I just don't get it. Sorry to be a newb.
03-10-2009, 11:03 PM
#107
91LQ1Lumina
the chra is the turbos center section, it houses the bearings and the thrust bearing. when i installed my new turbo it had no play at all and spun freely.
but after 5 mins on the car and idling it now dosenot spin as freely, it could be nothing, or i could have goten debri inside the scentersection form the machine work i had to do to it.
so my friend hooked me up with a rebuilt center section incase mine somehow got damaged
03-10-2009, 11:13 PM
#108
Awesome thanks for the info!
03-11-2009, 12:25 AM
#109
If I only had money!!!
is it a possibility the turbo isn't getting oil?
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
03-11-2009, 01:22 AM
#110
torq455
its deff getitng oil i pulled the feed line to verify that. its wierd when i shut the motor off and if i spin the blades by hand after a few seconds they free up.
but soon as i start the motor it does the same thing, it may be to much oil my motor makes 60-80psi of oil presure at idle, so i may try a restrictor and see what happens but i shouldnt need one, since im only using a -3 feed line.
first thing int he morning im gonna pop off the compressor and turbine housings and see if i see anything wrong, if not i will take the wheels apart and inspect the chra to see if there is debri or anything inside, and if i have to i will just replace the chra witht he rebuilt one i just got
any wich way ill have it back up and running tommorow, worst case senario is i put the 67mm turbo back on and swap the .82 housing off the 60-1 onto the 67
