View Poll Results: will it last more then 2 passes
Voters
38. You may not vote on this poll
  • hell no
    6 15.79%
  • yes
    9 23.68%
  • whop cares crank the boost and video it
    23 60.53%
Page 15 of 17 FirstFirst ... 5 13 14 15 16 17 LastLast
Results 141 to 150 of 163
Thread: will it survive 28 psi?
  1. #141
    ben assuming u called right before ur post time my car was on the dyno. i sent u a pm and will leave it upto u if u want to tell everyone about the issues we had.
    best pull was 268rwhp and 367.6 ftlbs @10 psi but that pull was aborted at 4,200 rpms
    as i told ben i setup another apointment for this wensday to fix a few issues that we had with the car.im not even gonna bother saying what they were.when ben hears it from jay the shop owner i will let him post up
    vids and pics of graphs should be up soon
  3. #142
    5,054
    oh no..... how bad has the shit hit the fan, ben?
  4. #143
    i didnt break nothing, though the dyno poped something during on of my pulls,
    suring my second pull we heard this loud band and all the sudden this loud hissing sound,soon as the bang wa sheard the pull was aborted, it seems liek an ait hose or something ruptered under the dyno but it didnt affect it in anyway.
    my issues were electronic issues and i prolly could have fixed it there but jay was being really cool and my car was on the dyno for a while and other ppl were waiting, so i said hell with it ill just come back so i didnt hold everyone else up
    ive made ben aware of the exact issues we had but i will let him hear it from jay and let him post them if he so likes or ill just post the new dyno numbers when i go back with the car sorted out
  5. #144
    5,054
    oh, i expected a piston/rod going through the oil pan/block or something to that effect.... sounded like the numbers were coming along nicely until the abort, yes?
  6. #145
    when that hose or whatever happened on the dyno came apart we thought i kicked the rods out of the motor it was friggen loud, when i get the vids up im sure u will see everyone jump and hear it
    well ok im gonna have to post up what the issues was for u to understand
    my peak hp and tq should happen up in the 5,500-6,200 range with the cam im using
    before the dyno i had reverted ignition control back to my stock ecm,not relizing that without the factory maf on the inlet of the turbo that the ecm would not advance ignition timing.so what we did was unhook the maf this set the ecm into limp home mode which pulls out all the ignition timing.
    we also verified this with a timming light on the dyno, max ignition timming was *8 btdc, no timming = no power and no ability to rev the motor up
    peak numbers occured right around 4k so they should have been much higher
    im not disapointed shit happens,i know what the issue is and its simple to fix so when i go back on wensday ill have some accurate numbers to post
    to make a best quess on what it would have done id say around 350rwhp if the ignition was advancing @ 10#'s of boost
    even witht he low hp number today im not really disapointed 370 ftlbs with how the car was dynoed is no small feat in its own
  7. #146
    5,054
    so at 10 lbs you figured you were making 350? so i guess you passed your 9psi/300HP guess earlier...
  8. #147
    we figure it should make that at 10 psi but we will see
    when we figured the 300rwhp was with the old turbo at 9 psi with a race wight of just under 3450 pounds,we did calcs to come up with that number and they are generally really close but not exact
    we did the calcs with et vs wirght and also checked it with mph vs car wieght one comes up as 311rwhp the other comes up as 307rwhp
  9. #148
    vid
    http://videos.streetfire.net/video/T...Day_641050.htm
    one the second pull after i let off u can her an air hose rupture under the dyno.we all thought for sure that i kicked the rods out of the motor,i shut the motor off soon as i heard it but after about 30 seconds we relized it wasnt the car making the noise
  10. #149
    damn almost 400 torque on 10 psi thats crazy ha ha its like taking the stock numbers an doubling them damn imagine what 28 psi will do
  11. #150
    Quote Originally Posted by nixon5 View Post
    lmao nex time i need to pull a tree stump i wont need to go borrow my friends truck lmao ill just hook a chain up to the camaro
    btw jay told me to figure 25% loss for the 700r4 and 4,500 stall converter
    so figure these are the flywheel numbers
    335 crank & 462 ftlbs
    not to shabby under the circumstances
