View Poll Results: will it last more then 2 passes
Voters
38. You may not vote on this poll
  • hell no
    6 15.79%
  • yes
    9 23.68%
  • whop cares crank the boost and video it
    23 60.53%
Page 17 of 17 FirstFirst ... 7 15 16 17
Results 161 to 163 of 163
Thread: will it survive 28 psi?
  1. #161
    I wish sometimes I didn't have to be so secretive...
    *heh heh heh.* Indeed
  3. #162
    still sounds like an old iron head '660.. lol
    judging by the vids it doesn't seem that fast to me, Get some track times and dyno numbers.. then you can make wild claims like "fastest 60v6 Camaro"
    I have the fastest Brown 1973 Datsun 240Z with a blue driver fender, ripped butterscotch driver seat, Autometer gauges, running a GM ECM, and rust outline where the vinyl top was.
    Beat that.
  4. #163
    heres the timing table im going back with
    that my table for 93 pump gas,when i switch back over to meth injection i will bump about 4-6* in under boost
