went to the track
just thought id share this is my 1994 cutlass dohc w/ wai
my times
run 1
reaction: .8363
60ft: 2.3953
330ft: 6.9299
1/8 et: 10.632
1/8 mph: 66.14
1000 et: 13.7600
1000 mph: 76.34
1/4 et: 16.5253
1/4 mph: 84.00
lost by: .7846
run 2
reaction: .7049
60ft: 2.4355
330ft: 7.0245
1/8 et: 10.7786
1/8 mph: 65.59
1000 et: 13.8989
1000 mph: 76.03
1/4 et: 16.7085
1/4 mph: 80.56
lost by: 2.2860
run 3
reaction: -.0018
60ft: 2.4108
330ft: 6.9457
1/8 et: 10.6667
1/8 mph: 66.24
1000 et: 17.7700
1000 mph: 76.48
1/4 et: 16.5308
1/4 mph: 84.13
lost by: .4563
run 4 (ran alone)
reaction: .5022
60ft: 2.4177
330ft: 6.8791
1/8 et: 10.5417
1/8 mph: 67.31
1000 et: 13.5829
1000 mph: 78.02
1/4 et: 16.2934
1/4 mph: 85.96
run 5
reaction: .3632
60ft: 2.4176
330ft: 6.9944
1/8 et: 10.7368
1/8 mph: 65.84
1000 et: 13.8566
1000 mph: 76.08
1/4 et: 16.6245
1/4 mph: 84.21
lost by: 1.0480
run 6
reaction: .2386
60ft: 2.5209
330ft: 7.1308
1/8 et: 10.8854
1/8 mph: 65.54
1000 et: 14.0074
1000 mph: 75.87
1/4 et: 16.7812
1/4 mph: 84.44
lost by: 4.1452
last run
reaction: .2836
60ft: 2.3828
330ft: 6.9593
1/8 et: 10.6892
1/8 mph: 65.99
1000 et: 13.7984
1000 mph: 76.44
1/4 et: 16.5584
1/4 mph: 84.36
won by: .1235
01-22-2010 01:58 AM
Olds Sleeper
DOHC should run better than that. My stock 3100 cutlass ( when it was that ) could keep up with that.
Jay
-Modded
-Modded
mine is a convertible and it was my first time ever to the track. look at the reaction times and 60fts that slowed me down some. im looking forward to getting back and trying again
Convertible will slow you down quite a bit. They weigh a lot more than a normal W. Were you bringing the revs up when you launched, or going right from brake to gas? I know when I had an auto there was a certain point where if i reved it more on the line it slowed me down (probably around my stall speed).
yeah i found that reving around 2k was good 2500 would spin plus i had bald tires and could barley launch
i ran a 15.1 at 92 with my 95 lumina dohc with intake and exhaust
Kaiō-ken X 10
Your 60fts are too high. You have to figure out your traction issue. Lower front tire psi and go a little softer off the line. You should be a mid to high 15 sec car. Thats 3100 teritory.
well i had bald touring tires before that i could just roast even at the 23psi i was running and a shot suspension
i now have upgraded suspension and high performance tires. cant wait to get back but i cant afford too i can hardly pay for gas LOL
Mr. Orange.
I managed a 16.0 @ 84.4mph with similar 60ft, so you must have been spinning. I did not spin but had a bad 60ft due to feathering it. Actually I had the best luck with traction with 40psi in the tires believe it or not with 205mm miss-matched all seasons.
So the times look about right, other than you are spinning which makes for the high time. This was with a stock 3100 at the time other than K&N drop in filter and a dynomax muffler.
One of your runs was almost 86mph, so if you had good traction that run you might have broke into the 15's.
