Page 1 of 30 1 2 3 11 ... LastLast
Results 1 to 10 of 294
Thread: Custom Intake Manifold
    Olds Sleeper kwhauck's Avatar
    Aug 2006
    Belle Fourche, SD
    373
    I have read the few outdated threads that there are about having a custom intake manifold.
    I would like to begin a new discussion about the pros and cons of taking either a 3400 or 3500 upper and lower intake manifold, and replacing it with one piece where you could mount a supercharger on top of it, similar to the 3.8 supercharged cars.
    First thing off of the bat i have considered the power steering pump and that is no big deal in my mind either through relocation or electric conversion, so lets just skip past that point, from their lets discuss drive belt routing, height issues, coolant line concerns, valley concerns, etc.
    Any thoughts?
    first thought is it would be freakin sweet. if one were made that was reasonable (not sticking a foot above the hood) im sure there would be alot of people interested.
    8,957
    I have been slowly working on a semi-universal intake manifold for awhile now, but just have too many other things going on, so it always gets put on hold. Maybe this weekend I can mess some more with mocking something up...
    Aug 2006
    Belle Fourche, SD
    373
    I saw some of your old pictures, and
    1. runners are super long and not meant to mount a supercharger
    2. you are just doing a UIM, i want to replace the upper and lower with just one manifold.......
    12,172
    Well, 1, that isn't what he is working on and 2, that still isn't what he is referring to
    8,957
    QFT!!
    RedZMonte's Avatar
    Feb 2004
    Loveland, Colorado
    1,318
    you would have hood clearance issues with a roots/twin screw charger... why not consider a Centrifigual charger (vortec). easy to mount, lower intake temps over Roots, easily intercooled, fits under stock hood, easier on trans, less traction issues and you can get different variations (like Turbo Trims), and most importantly more efficent....
    True Roots/Twin screw will make larger TQ number.. other then a Eaton you will have to rig up some sort of bypass valve (3800 guys have been screwing with this on the whipple trying to get it right).
    You can still design a better flowing intake 1 piece manifold to be used with the Vortec as well... without relocating anything...
    Just a few thoughts on the topic. I think this is why RSM did the Vortec's.... lol when they where around.
    Aug 2006
    Belle Fourche, SD
    373
    Could you at least give some hints or pictures as to what you are doing, even if by pm, this is a project that will go underway by me.....I just thought i would get a little informative discussion going, like, 1. I believe I would get move the power steering via an electric hydraulic power steering from a 91 toyota mr2. I, myself do not have the skills to build it, but from a price standpoint the intercooled supercharger setup top mount would not be much more that a front mount supercharger similar to the old EM setups.
    I have been talking a little bit with hogans racing manifolds....
    Quote Originally Posted by RedZMonte View Post
    I would have to argue about the efficiency of a vortech supercharger vs. a twin screw, there was a reason i got rid of the roots blower. It was limited for power and was a total heating problem at high boost levels, not to mention that the roots blower just pushes air where-as the twin screw actually compresses it, my 1600ax is actually smaller than the m62 and outflows it almost 3:1
    I have a bypass valve and I really don't understand what the problem has been for the GTP guys, it seems fairly straightfoward.....
    this guy incorporated a bypass into his custom manifold
    http://www.corneltechweb.com/superchargerweb.htm
    8,957
    Have you priced out one of Hogan's typical manifolds?! I hope we can produce something that is much cheaper, but we will see...
    As far as my thoughts... Well, my initial thought is to still have a 2 piece manifold, but quite different that the current setup, therefore allowing for many more top-end options, from a typical runner setup, to an SC setup, and possibly even a carb setup (for the RWD guys who want to keep it simple, but want the benefit of the alum heads).
    RedZMonte's Avatar
    Feb 2004
    Loveland, Colorado
    1,318
    check this out:
    http://www.modularfords.com/forums/s...ad.php?t=68838
    you would need to make it low profile like this to fit under your hood. I would also assume you would need some sort of chamber with a little bit of Volume to provide equil pressure to all cylinders... you dont want he boost to dump into a offset intake manifold and feed the back 2 cyl more air then the front 4, would cause them to lean out and cannot correct it with tune without making everything overly rich..
    Honestly i would look at doing a front mounted S/C like your eaton setup, easier to intercool and also you will get even boost pressure, not to mention allot less fab work, no coolant bypass ect..
    I still think you will need to make a little clearance in the hood... here is a M90 top mounted on a LQ1, not even close to fitting. I wouldnt rule out the votech personally...
    Dave96Z34 on mymonte, has a few pics of the build.. the problem he ran into is the 60* V6 is so tight its hard to make anything fit down inside between the heads.
