No, the OBDII links are ONLY scan tools, they do not support flash programming.
I was thinking more of this
http://www.scantool.net/scan-tools/p...5-compact.html
and then this software for better datalogging capabilities.
http://www.scantool.net/software/scanxl-std.html
If you want a programming suite, you need to find a DHP unit, or a HPTuners setup.
You may get better tools for scanning with the HPTuners setup right out of the box... I've found SOME things that work with the DHP unit, but not many.
04-29-2010 09:12 AM
I just installed my o;d 3100 computer and the car is feeling better, it will chirp in first ( witch it never did with the old comp) and seem to have a good top end. my butt dyno tells me its better but I have to try it on the track to see any actual differences. Oh and btw 3400-modified, if i datalog with my old computer would it be good to use as a base to tune my venture ecm?
Mike 60degree addict.
Data-logging with the Venture PCM is needed to tune that... I need to know where I'm starting. I could use a 96 ECM in its place, and edit those tables, then when done export them to the 97 file... But since there are some differing items between the two I would rather datalog and edit the ECM your going to use in the end.
I wonder whats amiss on the other ECM...
ill get the data logger next week. I just developped a exhaust leak at the rear cylinder bank. it seems to be bad. could it throw my ecm off too?
pocket-rocket
If it's before the O2.
i would go so far as to say before or close to... if there is any kind of reversion, then it could potentially draw in air during a pulse and mess with the O2...
PM me!
I was just keeping it simple
3400-modified, I just got lucky and found a DHP for cheap! I will be able to tune ! is ther any support at all for dhp?
Its been around a week ive been driving with the new computer and the car does not have a check engine at all. I am waiting on my PT and I'm buying a PLX for car too. btw way is the site for DHP is still working?
The Situation
yes the powertuner site still works plus you can go to uvscan forum and get that to do all the data logging. Uvscan is far better than what's built into DHP.
http://www.uvscanning.com/forum/
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
