Results 1 to 3 of 3
Thread: ARP Part # for Head Studs????
    Can someone please confirm that the head studs for the 3400 are the same as the 2.8. ARP has two part #s for the studs and they are
    233-4003 11mm hex
    233-4303 11mm 12 point head
    I also need to know the pitch of the threads to get a chaser 1.25, 1.50 or 2.0
    Thanks abunch
    Dec 2005
    Plainfield CT
    3,057
    2.8 numbers are not the same for the 3400.
    3400 studs are 11Mx1.5 for the block side, and the nut side should be a 7/16-20
    I'm not going to post Part numbers since the item is sold in the WOT-Tech store, and trust me that's the cheapest price you'll find. There is no kit for the 3400 so you will have to piece it together and it will cost more in the end.
    Quote Originally Posted by 3400-95-Modified View Post
    Thank you, so does anyone have the ARP part # for the head studs for the 2000-2005 3400?
