ive noticed recently that the engine rpm is staying at 1100 rpm when stopping at a traffic light then it
finally drops down to idle . the other day i pulled up to a light an the rpm stayed up at 1500 an it never
dropped down .i had to really hold the brakes . after 5 miles or so it quit acting up.
the throttle cable appears free . anyone seen this before?
i thought maybe there is something going one with the cruise control. but how would i go about disconnecting it?
hi Ben , yes there are no codes present. i did recently have an egr code where the tech felt like the egr passage was plugged up in the intake. he ran some cleaner thru it an its been clear since. ill check into the IAC as you recommend.
sounds like i need to pull the intake an clean it..
thankyou for the info guys . i have not had anymore trouble with it since it did it last thursday.
not that it has anything to do with it. but i did realize that the cruise sw was in the on position.
the ink has faded away .had to get the owners manual out . to see the sw position .
when i get off shift at work. ill spend sometime an check the iac out.
86 i dont know how to do an idle relearn? would you guys explain it for me.
rob
If your battery has been disconnected for about 15 minutes or so, you may need to perform this procedure in order for the computer to relearn how to idle. Under most circumstances, it will relearn after just driving the car for a while, but if your car continues to experience an abnormal idle, or you just don't want to wait for it to relearn on its own, you can try this procedure.
How To Do It
Step One
Restore battery power and turn off air conditioning controls.
Step Two
Run the engine up to operating temperature and shut off.
Step Three
Apply the parking brake. Start the vehicle and place it in drive (A/T), or neutral (manual).
Step Four
Run the engine until the cooling fan has cycled on and off, or for a maximum of 10 minutes.
Step Five
Turn the ignition key off for at least 5 seconds.
Step Six
Restart the engine and again shift into drive or neutral. Allow engine to run for at least 5 minutes.
Step Seven
Shut off engine for 10 seconds and restart.
Step Eight
That should do it. With engine stabilized and in closed loop, the IAC motor values should be between nine to 12 counts. If not, the adjustments may be tailored by adjusting the minimum air rate screw. More throttle valve opening equals lower IAC counts. Less throttle opening equals higher IAC counts.
