Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: Help me boost my 3400
  1. #31
    Feb 2007
    Clarksville, TN
    42
    10x injector rating means that you would be at 100% of the duty cycle of the injector at the 240 hp point. It's probably a better idea to size your injectors so that they aren't at 100% for any length of time. I would plan on using injectors that are at 85% of the max duty cycle.
    Like Sappy says, BFSC is an educated guess. For gasoline powered engines BFSC is around .45 (very lean) to .60 (very rich). For actual operation .45-.5 is probably more realistic. During wide open throttle operations you want to be on the rich side, so on a turbo-charged engine .6 BFSC is a good conservative guess.
    I know you don't want to hear about formulas but sometimes it's the best way to understand this stuff. You can use the following formulas to give you a ballpark idea what size injectors you should use and what HP you would be capable of.
    Fuel Injector Duty Cycle=HP*BFSC/#of injectors/(injector lb/hr)
    If you dyno'd the engine and knew the exact horsepower output you could plug the number in and see exactly what your injector duty cycle is at that max HP. Since you don't know what the HP output of the engine will be you can switch the formula around to find out the HP the 36# injectors will give you at 85% duty cycle:
    Max HP = 36#*6cyl*.85dutycycle/.6BFSC = 306 Max HP, a conservative estimate that puts you close to your 300HP goal without worrying about exceeding the 100% duty cycle of the injectors. Probably something GM figured when they supplied the 36# fuel injectors in the L67 at 8 PSI.
  3. #32
    Thanks! From what I have read the 3.8sc injectors swap for my '02 3400 injectors, is that right?
  4. #33
    Feb 2007
    Clarksville, TN
    42
    Quote Originally Posted by Bridgetown View Post
    They should.
  5. #34
    RedZMonte's Avatar
    Feb 2004
    Loveland, Colorado
    1,318
    I am also higher altitude, about +1000 feet.
    ROTFLMAO! i would trade you in a heart beat! im at 5000+ Ft Elevation. Either turbo will be fine. Im running a T04E "60" (T4) and i spool fine at elevation with cast manifolds, and crush bent 2.5" DP.
  6. #35
    Picked up a couple items off ebay to start the build.
    3100 manifold and 2 bar map.
  7. #36
    Feb 2007
    Clarksville, TN
    42
    Someone over at the Fiero forum is selling a set of 36lb injectors.
    http://www.fiero.nl/forum/Forum4/HTML/053017.html
  8. #37
    Here's yer sign
    Nov 2003
    Pennsylvania
    135
    What is that manifold off of? I know my beretta 3100 and minivan 3400 rears dump out the middle. I'm wondering bc if I remember right some manifolds are almost channeled towards the downpipe while yours looks like it would flow better and work well with wastegate mounting if it would clear my firewall....
    95 Z26 3400/OBDII/GETRAG
  9. #38
    I beleive that is is off of an early 3100 car. I can't say for sure. I baught it off Ebay, I paid more but figured that I would spend probably 2+ hours getting a rusted seized one off a junkyard engine. Worth the extra in my mind. I am planning to do a little smoothing work in the outlet area to promote better flow. As far as using a stock GM manifold for a turbo application, I think this one is the best option.
