Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Rich boost issue
    Mar 2006
    Tampa Florida
    1,635
    no way would i even suggest trying to run boost on something made specifically for 1BAR.
    That's very wise, but in the early days of boosting computer controlled cars it was done effectively even by big names such as Paxston. I did it for years until more information and access to engine management controls came available. If you understand how the ECM functions along with the fundamentals of engine operation it's quite easy, however, you will be limited in how much boost you can run before richening fuel and reducing timing in the chip at 100 kpa just isn't enough. For me that was 7 psi, but it could have been the result of overwhelming the injectors or fuel pump that put up a wall when I tried to achieve 10 psi.
  3. #12
    5,054
    true, but these days, those comprimises don't have to be made... and for the price it runs to do it right, i can't see someone justifying using stuff like RRFPRs anymore(unless you REALLY need the extra pressure along with proper tuning).
  4. #13
    Sep 2009
    Camby, Indiana
    85
    I installed the MSD 6AL ignition box and now at first at WOT/boost it is a 10.0 and then as the RPM's increase to red-line the AFR goes up slowly to 12.6 just before I lift. Is this, in your opinion not too lean? what range is goal boost afr?
    1992 Grand Prix SE 3.1l 155k SOLD
    1992 Grand Prix GTP 3.4l 55K
    1991 Grand Prix GTP 3.4l 5 speed 99K SOLD
    1988 Pontiac Fiero GT 2.8 5 speed Turbo 36K Sold
    2011 Mazda 3s 5dr 6 speed
    2008 Grand Prix GXP 5.3l 24K sold
  5. #14
    5,054
    depends on the motor... someone on w-body just had their 5 speed TGP dyno'd and after looking at all of the fuel spikes/dips, it seemed to make the most/smoothest HP/TQ at 11.6:1 according to a WB(not sure if it was a tailpipe version on the dyno or what).
  6. #15
    Sep 2009
    Camby, Indiana
    85
    hmm, okay how would I know if I am too lean then?
  7. #16
    Sep 2009
    Camby, Indiana
    85
    The tuner found that it was too lean under boost, and that there were stock injectors. They replaced with beefier ones and deleted the EGR. I was a little disappointed that at 8PSI it was only good for 183/230 on the dyno. The guy that sells the 8PSI kit design one or whatever says his kit is good for 200hp. Maybe the tune on my car is now very conservative.
