Results 1 to 2 of 2
Thread: Revised manifold bolt torque
    12,172
    The WOT-Tech Competition Manifold Set requires the following torque procedure. Failing to follow these directions may result in a cracked manifold. This is a common issue even for stock manifolds when overtightened, but is even more important with the port work that has been done.
    Lower Intake Manifold
    Center bolts : First Pass = 62 lb in
    Final Pass = 115 lb in
    Corner bolts : First Pass = 115 lb in
    Final Pass = 18 lb ft
    Start with the center bolts, then corner bolts, then final tq on the center bolts, and finish with the final pass on the corner bolts.
    Upper Intake bolts: First Pass = 115 lb in
    Start with the middle bolts, then the outside for the first pass, and repeat for the final pass.
    12,172
    I include these directions with every manifold set. Any feedback is appreciated.
