Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: timing chain broke
    Accelerating uphill in OD Azrael's Avatar
    Apr 2005
    Selkirk, Manitoba
    763
    With the crank mark pointing up and the cam's down, #4 should be at TDC compression and #1 will be at TDC exhaust.
    1995 Grand Am SE
  3. #12
    Valve damage *can* occur on these when the chain breaks. Since you have the timing chain installed correctly, you're likely looking at some valve train damage.
  4. #13
    Mar 2006
    Tampa Florida
    1,635
    Quote Originally Posted by mfewtrail View Post
    I agree, as with direct ignition systems it shouldn't matter whether cyl 1 or 4 is on the compression stroke because they both get a spark regardless. This is important on an engine with a distributor.
