08-21-2010 11:03 AM
The Situation
not bad it's got a nice steady idle.
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Mr. Common Sense
Sounds good......very similar to mine (yours is just a bit louder).
Had it tuned yet? I saw some pretty decent gains after tuning with similar mods.
Very nice
Idle quality videos can really help people figure out which cam they want. That engine bay looks great too!
6 > 1
I heard the same cam running on OBD1 in a 3400 with headers and it sounded quite a bit different... maybe the SFI is helping it out...
Sounds good though, very smooth.
what chain did you have prior? i would like to know if the 99 gm chain holds up with this cam...
I was using the OEM, witch was very small. This chain streched in 5K, but this is do to the valve springs. I hear the pre 99 work great, but now I'm running the TCE timing kit with crank.
Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
I have my 99 GM setup on there still and its holding up good. As noted though, its typically the springs that your using that will also speed up chain wear. I also had my chain cryogenically treated so that may be helping a bit. TCE is a nice solution, but I'm not up for tearing the whole motor apart again to have the crank turned.
Wow hearing jon's car and now your grand am. I want a cam really bad.I would really like to do a engine build in the very near future.
