3400 heads
Just wondering I have a 95 beretta with the 3100 sfi and I wanted to swap the 3400 heads from a 03 Montana into my car what all should I get from the van? Also what is a good set of headers that I could get, and where can I get them? Thanks a bunch.
08-27-2010 08:29 AM
Welcome to the site!
If you get the heads, get the entire top end as well. Or, just swap out the entire engine, and really get some gains. As far as headers go, this is about your only choice... http://wot-tech.com/shop/all/beretta.../prod_251.html
But should I grab the ECM or anything like that? Or any other components that I might need?
Nope. Have you decided what route you plan to go? That will define what parts you need.
Prolly just the heads. If I could find a 3.5 then I'll grab those heads but prolly just the 3400.
If you are just going to do the heads, then the only thing I can think of would be the coolant temp sensor. In early 3x00s, there was one mounted in the read head. In later engines, this was done away with and they went with a 3-wire sensor near the thermostat. It is a relatively easy upgrade.
If you decide to do the intakes (or even if not, still a good read), check out the following swap guide: http://www.3x00swap.com/index.php?ma...t01returnid=53 . It is for swapping a complete engine, but covers all of the differences between the engines, which would also be applicable with just a top end swap.
3500head on a 3100 is a no-go
Mike 60degree addict.
mickaz
Missed the 3500 in that last part, but yeah, the combustion chambers of a 3500 head overlap the 3100's bore, so you can not use them.
Ok cool sounds good I'll just do the top end from the 3400. What else could I do to get more power after I do the swap? Any ideas?
before doing something over another one,You have to be sure on what your getting into.
a 3100 with 3400 heads will give you around 170HP
a 3400 will give you around 180- 200 HP
a 3400 with 3500 head around 190 - 210HP
a 3500 ( what i suggest) 210 +
this is on the great side of things, meaning your engine is in good shape or is low mileage.
for what you have to do ( Ive done em all) and Money wise, the 3500 will be the strongest in the long run
And it is the cheaper ( no rod bolts, gaskets, and top end to buy separate.)
the 3500 need a crank trigger and ( recommended) a 65mm throttle body
And you have a 95 and its an OBD1.5 you have to check your options for tuning: downgrade to OBD1 ( to get a chip) or upgrade to OBD2 ( get a programmer)
