DTC P1640 Driver-1-Input High Voltage
  • funair8594
    • 20
    Any ideas?????
    Can't figure this one out.
  • Juglenaut
    • Dec 2003
    • 1130
    This is a general search
    I am back
    Mechanical/Service Technican
    • funair8594
      • 20
      I've tried to reseach this in the free time and here's all I can come up with....
      This code is kicked in when the Quad control module of the PCM detects a overvoltage condition for 20 seconds in 4 or 5 different and various sensor and/or switch circuits.
      I cant remember all of them, but some of them were the charcoal canister valve, the EGR, the coolant temp sensor, and 1 or 2 others.
      It's a soft code--it pops on only for a second or two and then goes away, usually, for the remainder of the drive.
      I suspecting that one of these sensors is out of spec and needs replacement---maybe. To me, it sounds like one of the sensors or switches are not working for a brief time then kicks on.
      The Z runs great. This code just started on day. Now I get it just now and then. The car has no problems to speak of, except for the headliner is starting to fall down It just pizzin me off
      • Cliff8928
        • 532
        What car is it for? I can get a PDF of the diagnosis for that code..
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
        • funair8594
          • 20
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          Cliff--its for my Lumina 94, 3.4 dohc.
          I would like to look at it even if its not for my car. Just something to go on would be nice
          funair85@netzero.net
          Tx.!
          • Cliff8928
            • 532
            That's strange, GM used the OBDII Designations before OBDII was in effect.... I can't get the info for a 96 (earliest year i have info for), 'cause P1640 isn't a valid code for a 1996 model..
            Only thing i know about that is it's a Quad Driver Module A Error...
            Cliff Scott
            89 BerettaGT
            89 Volvo740
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            • funair8594
              • 20
              Cliff Scott
              89 BerettaGT
              89 Volvo740
              I know it is wierd. GM did something like 1/2 OBD II in this Lumina I have. 1994 has OBDII, but not all the normal sensors.
              I cant really find anything on this code. Even my friend (whos a driveability tech) has put this on the snap-on scanner, got the code and it says in the snap on book to consult the mfg for this code?!?!?!
              I think it just means that its running too good hehehehehehehheh j/k
              It just pizzes me off. About a year ago, I tore down the whole motor to fix the dist oil ring. I did the best job i could with everything. The car runs GREAT and is pulling 15-15.4 even with the auto. I even used a torque wrench
              why do I have this code?!?!?!?!?!
              • Juglenaut
                • Dec 2003
                • 1130
                I may just be a defective fault code that is not suposed to pop into resident memory trigger. This certain code shows to have a long history in searches.
                If it is possible I would just mabey have the code render deleted from the binary set, but don't take my word for it. covering my (l)
                I am back
                • Cliff8928
                  • 532
                  A Quad driver code is definately something you do NOT want to have... it has to do with some of the transmission controls, the EGR valve, some other things on the engine... A friend had a wire messed up on his EGR and it caused all sorts of funky things with the trans and the way it ran, etc..
                  Cliff Scott
                  89 BerettaGT
                  89 Volvo740
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                  • funair8594
                    • 20
                    more diagnosis tomorrow I think I may be on to something
                    Im going to do a little more research tomorrow.
