Turbo Help asap
  • d.o.h.c
    • Jun 2004
    • 981
    Turbo Help asap
    Ok guys I am trying to get my 3.4 dohc turbo started but am haing ssome problems. I crank it over and get no oil pressure out of my gauge, but I have oil coming out of the turbo. So that leads me to my first question. I dont hvae a wire going from the aux post to the started,just have the starter directly hooled up to the battery. Is this a problem? And would this cause the headlights to not work? next question. I have fuel pressure and when I tryed to start it , it just turns over. It sounds like its about to starte but doesn't. Anything I should check for. I mean it should run, I dont know how good but it shouild. Hte motor is rebuilt and the coils are msd brand new, magnacore wires brand new. What should I do?
  • Joseph Upson
    If your headlights are not working chances are you have no power to the gauges either. Do you have any hot wires other than the positive cable connected to the starter terminal with the battery cable?
    • d.o.h.c
      • Jun 2004
      • 981
      Yep, I have not power to the lights on the gauges. But on the a/f gauge I have a reading and the oil I have nothing. I ran the same power wires and ground to both.
      • gpchris
        • Feb 2007
        • 477
        If you talking about the post thats on the fuse box then yes you have to have a cable going to it or it will not start.
        • d.o.h.c
          • Jun 2004
          • 981
          Why is that. I thought that it was only for the hedlights.
          • gpchris
            • Feb 2007
            • 477
            I have no idea but i know from experience that the car won’t start without it.
            • d.o.h.c
              • Jun 2004
              • 981
              You got it guyes. I will have to make one tomorrow.
              • patgizz
                The Plaid Bandit
                • 1071
                depending on the year that post powers anything from interior stuff to fuel pump. the W body harnesses changed several times through the gen1 run.
                • d.o.h.c
                  • Jun 2004
                  • 981
                  Perfect. I will make the power wire and attach. Should
                  • RedZMonte
                    • Feb 2004
                    • 1378
                    hook everything back up to stock. double check all wiring and also double check the oil feed line to the turbo and also your oil pressure sensor. if everything looks correct there. again double check your wires to the post. hook everything back up no short cuts. if it ran fine before the turbo install it should run and idle fine after.
                    • d.o.h.c
                      • Jun 2004
                      • 981
                      Its a brand new motor, but with the last motor it did run perfect.
                      • d.o.h.c
                        • Jun 2004
                        • 981
                        OK I have fuel pressure and spark. So I am thinking its injectors.
                        • d.o.h.c
                          • Jun 2004
                          • 981
                          Ok guyes I found out my injectors are bad. So I was going to buy the 42# injectors. My question is. Can I run them with the fmu. I just dont want to blow up my car
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            Are these the injectors I buy. EV1?
                            • d.o.h.c
                              • Jun 2004
                              • 981
                              whats the difference between the two sets they have. I need to know asap, So that I can get these ordered next day
