Warning: count(): Parameter must be an array or an object that implements Countable in /home/wottech/public_html/vb5/includes/vb5/template.php(392) : eval()'d code on line 5 3x00 Exploded View - 60DegreeV6.com
3x00 Exploded View
  • 3x00 Exploded View
    Click on a number corresponding to the part you are looking for information on. This will load a new page with detailed information (part numbers, specifications, description, etc) for the part. This is a general breakdown of parts. With that said, there may be some parts not shown that are on a specific platform. There may also be some parts that are shown that are not on all platforms. Several items vary over the years as well, and any variances should be covered in the detailed description page for the particular part.
    ** This is a work in progress. Not all parts have information filled out yet.
    3x00 Exploded View EGR Valve Gasket EGR Valve Assembly EGR Valve Pipe Gasket EGR Valve Assembly Bolt EGR Valve Pipe Assembly Spark Plug Support Bracket Bolt Wire Harness Bracket Upper Intake Manifold Bolt MAP Sensor Bracket Upper Intake Manifold Bolt Upper Intake Manifold Spark Plug Support Bracket Radiator Surge Tank Bracket Thermostat Bypass Pipe Thermostat Bypass Pipe Nut Thermostat Bypass Hose Clamp Thermostat Bypass Hose Thermostat Bypass Hose Clamp Thermostat Bypass Pipe Screw Coolant Outlet Bolt Coolant Outlet Assembly Thermostat Upper Intake Manifold Gasket Electronic Ignition System Bolt Electronic Ignition System Bolt Electronic Ignition System Electronic Ignition System Nut Spark Plug Wire Support Evap Canister Purge Valve Evap Canister Purge Valve Bracket Evap Canister Purge Valve Stud Exhaust Crossover Upper Heat Sheild Exhaust Crossover Pipe Exhaust Crossover Nut Oil Fill Cap PCV Valve PCV Valve Grommet Rocker Arm Cover Bolt Rocker Arm Cover Fuel Injector Wiring Harness Fuel Injector Rail Assembly Bolt Fuel Injector Rail Assembly Heated Oxygen Sensor Right Exhaust Manifold Upper Heat Shield Right Exhaust Manifold Upper Heat Shield Bolt Right Exhaust Manifold Right Exhaust Manifold Nut Right Exhaust Manifold Stud Right Exhaust Manifold Lower Heat Shield Bolt Right Exhaust Manifold Lower Heat Shield Right Exhaust Manifold Gasket Lower Intake Manifold Lower Intake Manifold Diagonal Bolt Lower Intake Manifold Vertical Bolt Engine Coolant Temperature Sensor Intake Manifold Coolant Pipe Valve Rocker Arm Bolt Valve Rocker Arm Pushrod Valve Spring Cap Key Valve Spring Cap Valve Spring Valve Stem Oil Seal/Valve Spring Seat Assembly Cylinder Head Bolt Cylinder Head Bolt Cylinder Head Bolt Cylinder Head Lower Intake Manifold Gasket Exhaust Crossover Stud Left Exhaust Manifold Gasket Left Exhaust Manifold Left Exhaust Manifold Stud Left Exhaust Manifold Nut Left Exhaust Manifold Heat Shield Bolt Left Exhaust Manifold Heat Shield Intake Valve Exhaust Valve Cylinder Head Gasket Left Spark Plug Wires Right Spark Plug Wires Camshaft Sprocket Bolt Camshaft Sprocket Camshaft Thrust Plate Screw Camshaft Thrust Plate Camshaft Sprocket Alignment Pin Camshaft Front Camshaft Bearing Intermediate Camshaft Bearings Rear Camshaft Bearing Upper Piston Compression Ring Lower Piston Compression Ring Oil Control Ring Assembly Piston Pin Piston Connecting Rod Connecting Rod Bolt Upper Connecting Rod Bearing Insert Lower Connecting Rod Bearing Insert Connecting Rod Bearing Cap Connecting Rod Bearing Cap Nut Oil Pump Drive Clamp Bolt Oil Pump Drive Clamp Oil Pump Drive Assembly Oil Gallery 1/8 inch Plug Oil Gallery 1/4 inch Plug Camshaft Rear Cover Coolant Jacket Press-In Plug Transmission Dowel Pin Valve Lifter Guide Bolt Valve Lifter Guide Valve Lifter Camshaft Position Sensor Bolt Camshaft Position Sensor Crankshaft Position Sensor Side-of-Block Stud Crankshaft Position Sensor Side-of-Block Coolant Jacket Press-in Plug Coolant Drain Plug Oil Filter Oil Filter Fitting Engine Block Knock Sensor Oil Gallery 1/4 inch Plug Oil Gallery Press-in Plug Engine Front Cover Gasket Timing Chain Dampener Timing Chain Dampener Bolt Engine Front Cover Alignment Pin Drive Belt Tensioner Drive Belt Tensioner Bolt Engine Front Cover Crankshaft Front Oil Seal Engine Front Cover Bolt Engine Mount Support and Strut Bracket (N-car) Engine Mount Support and Strut Bracket Bolt (N-car) Water Pump Gasket Water Pump Water Pump Bolt Water Pump Pulley Water Pump Pulley Bolt Crankshaft Position Sensor Crankshaft Position Sensor Bolt Crankshaft Balancer Bolt Crankshaft Balancer Washer Crankshaft Balancer Crankshaft Sprocket Timing Chain Crankshaft Balancer Key Crankshaft Crankshaft Upper Main Bearing Insert Crankshaft Lower Main Bearing Insert Rear Crankshaft Oil Seal Engine Flywheel Engine Flywheel Retainer Engine Flywheel Bolt Oil Level Indicator Assembly Crankshaft Main Bearing Cap Oil Pump Alignment Pin Crankshaft Rear Main Bearing Cap Crankshaft Main Bearing Bolt Oil Pan Gasket Oil Pump Drive Shaft Oil Pump Oil Pump Bolt Crankshaft Main Bearing Cap Stud Crankshaft Oil Deflector Crankshaft Oil Deflector Nut Oil Pan Side Bolt Oil Pan Drain Plug Oil Pan Drain Plug Washer Oil Pan Low Oil Level Indicator Low Oil Level Indicator Bolt Oil Pan Bolt Oil Pan Side Bolt Starter Motor Starter Motor Short Bolt Starter Motor Long Bolt
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
