IAT stands for Intake Air Temperature. It is a simple thermistor that changes its resistance according to the temperature it is at. The idea beind this modification, is that by changing the resistance to that of a cooler interpreted reading, you will get more fuel. While it is true that you will dump more fuel...its false that this is a good idea. Running rich is bad for performance, so you are just wasting your time with adding more fuel in this fashion.
The stock computer already compensates fuel as it is, so trying to trick it into giving you more fuel is completely worthless. If you dump too much fuel, via switching to a colder resistance on the IAT while driving, you may even notice a puff of black smoke out the exhaust. Then, the O2 sensor will detect the overly rich mixture, and reduce the injector pulse width. This totally defeats the purpose or the IAT mod.
Categories
Article Tags
There are no tags yet.
Latest Articles
by bszopiPort injection The TB spacer is meant to keep the throttle body cooler, by separating it from the manifold using a phenolic material instead of metal. The misconception is that by adding space behind the TB, you are going to get more torque. The lowered temperature is fine, and is worthwhile (see TB coolant bypass), but the cost of a spacer and the remaining intake manifold temperature doesn't do a whole lot on its own. The performance myth with this device is that it allows more air in...
Channel: Myths
05-31-2010, 05:32 PM -
by bszopiA heat shield made out of aluminum is nothing more than a heat sink. The heat from the heads going to the manifold, with the throttle body attached to it will be a far greater source of heat compared to the exhaust manifold that is not attached to the throttle body. There are better ways to decrease intake air temp, with this one giving absolutely nothing in return for your money.
Channel: Myths
05-31-2010, 05:31 PM -
by bszopiThis isn't so much a myth, as it is exaggerated. The lines were put in by GM for cold climate conditions, which is said to cause ice to form on TB, which could cause a lot of problems, like a stuck open condition that can cause an accident. There have been no known reports of this happening, but there hasn't been any research either. ...
Channel: Myths
05-31-2010, 05:30 PM -
by bszopiThere are several different versions of this myth floating around.
Here is one view on why electricity and boost don't mix: Click Here!
Channel: Myths
05-31-2010, 05:28 PM -
by bszopiI'm going to keep this short, because its a simple concept. For years people have been spreading the word that a 160 stat will cause problems. This is true, as it hurts gas milage and MAY cause the cylinder walls to wear faster due to less expansion. If your fan turn on times aren't matched, it can allow a cycle of 160 to 220 degrees back and forth, which will contract and expand the cylinders. ...
Channel: Myths
05-31-2010, 05:26 PM -
by bszopiIAT stands for Intake Air Temperature. It is a simple thermistor that changes its resistance according to the temperature it is at. The idea beind this modification, is that by changing the resistance to that of a cooler interpreted reading, you will get more fuel. While it is true that you will dump more fuel...its false that this is a good idea. Running rich is bad for performance, so you are just wasting your time with adding more fuel in this fashion. ...
Channel: Myths
05-31-2010, 05:07 PM -
here is how the IAT mod "works"
it adds both advance and fuel via a few tables in the ECMs. i'm going to explain it and show with a 90 grand prix 3.1(running on the A1 mask), since i play with the most.
you'll feel better throttle response due to more AE(accell enrich) fuel being commanded, and pretty much more fuel will feel better, up until you get past the point of roughly an instantaneous ~12.9:1 AFR, then you'll start getting into a rich bog. now, you'll notice that the AE added also goes up at higher temps; this is to help cool the motor, since if you're sucking in ~300*F air, you're likely damaging something and fuel will evaporate, giving a small handicap. also notice the basically 0 number at -40*F; that is what you'll get if you disconnect the IAT altogether.
next, we have another fuel modifier, but this one doesn't deal with throttle response, it has to do with adding more fuel at all times(until the O2 sensor corrects for it); airflow multiplier vs IAT(technically, airflow doesn't multiply based on temps, but it does get denser at colder temps, meaning more oxygen molecules for the fuel to bond with during combustion), and as we see, almost a linear change in the air temp vs the amount of air that is "multiplied".
now, for spark i have to switch to a different mask since A1 doesn't modify advance based on IAT, so i'll move to 1FA(94-95 3100 A-body), and as you can see, only when you move beyond 46*C(since the PCM interpolates the table) will you get any change to the advance and it looks like it will pull a maximum of 4.25* of advance depending on load.
so, there ya go, that's what the IAT mod will net you: lying to the ECM/PCM to trick it into more fuel and advance, something that would be better done through actual tuning.
