3500 Swap Guide.
  • 3500 Swap Guide.
    Hi
    I want to help out people that wants an 3500 in their car. I want To make a GENERAL guide. So If you have pictures and info ( because I know how to install it into a Beretta 96) but the older platforms needs others stuff, so...I will base it on the 3400 swap guide.
    So If you want to help me it will be greatly appreciated.
    Mike 60degree addict.
    I have 3500 parts laying around if you need some good pictures. Just tell me what you need.
      Thanks will need a couple soon.
      I need help from someone that did the swap on a J body, since J and L are close to each other i will do one for both.
        As stated in some thread around here, check out the sticky post in the Pushrod Performance area for info pertaining to the W-body.
          yeah well I have to read that again?? LOL naw I allready started and I wasnt sure If I should add the N and W body. because I dont know em as much as the others platforms.
            i can give u some j info but im third gen not second.
              hmm.... jonpro just recently threw a 3500 into a TGP.....
                Ohai!
                Lotsa good info:
                including running a 3500 with a non-electric trans and kickdown cable, how to (theoretically) use the 3500 trigger with megasquirt and coil on plug, wire the megasquirt into the TGP harness with options like TCC, etc...
                Im not done with it yet though...
                  okay this is the beginning of the guide. ( higky based on the 3400 guide)
                  GM 3500 V6 Swap Guide.doc
                    Looking good so far. I assume you will try to add pictures as well?
                      yes I will have to find the pics since i never took pics of my swap.
                        anything new with the swap guide? im looking forward to it cuz i wanna do the swap.
                          I'm still working on my swap, but nothing so far that is helpful as far as pictures for the guide yet.
                            I have lots of work/school so It had to wait should be finished next week.
                              8 years dead, I know - but for the record, Milzy Motorsports has a fairly comprehensive writeup/guide on their site. I used it for mine and aside from the troubleshooting you may have to do when you're ready to run the engine, I found it most useful when I did my Impala 4 years ago.
