3400/3500 hybrid compression
  • 3400/3500 hybrid compression
    Hey guys I'm not sure if this info is already out there, but I'm new to the site and was wondering if someone could help me out.
    I plan on using the 3500 intake manifolds on my 3400 and using the F-body pistons. Now I know the pistons will significantly raise the compression, and switching from the 3400 to 3500 manifolds will lower it down a bit again. Does anybody know what the actual compression ratio for this set up is (or atleast an educated guess)? Also how high of an octane would you suggest for this set-up?
    3.4 pistons and 3500 head gaskets gives you 11.56:1. Close enough?
    Welcome to the site!
    -John
      Thanks for the quick response. I'm looking forward to learning alot on this site, lots of info laying around.
      So roughly what kind of hp increase would I be looking at from going from a stock 3400 to a 3400/3500 hybrid with 3.4 pistons? The engine will be properly tuned afterwards.
      What type of gas is recomended with this setup? I'm sure pump gas would be fine but how high of an octane would you say is necesary?
        if you get a tuner you can use any gas so that you can tune KR out after your build
          Are you changing the heads as well or just the intake manifolds?
          Does changing solely the intake manifolds alter the compression?
          Hope I'm not hijacking, welcome to the site and look forward to hearing more about your build
            No, so I'm assuming he meant heads. I also wouldn't consider a simple question about the subject hi-jacking either
              Heads and manifold will have to match pending the generation of engine parts are used, Fierball.
