03 GAGT LX9 and Getrag F-23 swap!
  • #61
    Grand Prix gxp rotors on kijiji
    2000 Chevrolet Malibu LS (LX9-F23 swap soon!) Slowly acquiring parts!
    • #62
      Originally posted by carbon View Post
      Excellent! Love the early AL control arms too...
      Thanks, what a bitch those were to polish
      Originally posted by Maple Leaf View Post
      Thanks man, but finishing my rear brake upgrade is the last thing on my mind right now lol
      3" turbo back, charge pipes, and wastegate plumbing arrived as well as my intercooler
      Was hoping to get the DP passed the subframe but I couldn't remove/install it if it was any longer then what it is now
      • #63
        TCE 1.25" phenolic intake spacers
        Hood didn't close lol
        the culprit
        will clean this up later
        mounted my intercooler as high as it would go between the crash bar...
        this bump was getting in the way of going higher
        much better!
        charge pipes!
        • #64
          So I spent some time finishing off my last charge pipe and came up with this contraption
          which put my MAF down here
          Not even 24hrs later and I chopped off half of that charge pipe and started from scratch though lol but happier with the placement of things, I'll grab some pics later when it's not so dark in the garage
          • #65
            This should be better, might still mess with a small section of the charge pipe by the TB bracket
            Decided to get a new wastegate to get a much smaller design and v-bands, also went with 44mm VS the 38mm Emusa
            Going to be sitting something like this, still need to cut that pipe down a bit
            • #66
              if youd like to sell the purple one let me know.
              Sent from my iPhone using Tapatalk
              • #67
                Might as well update this I guess, it at least give me a nice "journal" of my build lol
                Got my drive train out a little while ago
                Inspected my "stage 3" ebay clutch and rather happy with it after 16,000+kms with no proper break in and beating the shit out of it
                drilled my pan for oil drain, thought I could get away with a nut and loctite but not enough thread showing
                So dropped it off at a local shop that I use for my TIG welding(Re-Speed) and some beauty cars out front
                Last year I lost my steering rack tabs.... NOT this year or anytime soon lol 1/8" plate on both sides
                Lifted fuse box 1" and relocated wires from the front out the back
                last year I had some TERRIBLE traction issues the 2 times i hit the track... Got a closer look at my poly rear mount and damn?
                New one is here so little fire with the old lol
                GTP 36# inectors/connections and my PCM flashed for them thanks to Scott!
                ohh and got myself a WOT-Box for some 2-step launch control and no lift shift
                • #68
                  3500 LX9Getrag F-23 5 Speed65mm LX5 TBBorg Warner S300 turbo44mm wyntonm external wastegate50mm BOVGTP 36# InjectorsTCE 1.25" Phenolic intake spacers3" open ...
                  3" downpipe, wanted it to be 1 piece but wasn't happening
                  Girlfriend painting all the exhaust parts with some POR-20 heat paint
                  Some heat management
                  Quick clean to make sure no debris was inside
                  Notch for oil return
                  Screamer pipe
                  • #69
                    Words can't describe how much I ****ing love this thing! Lol
                    Quick driving video
                    video, sharing, camera phone, video phone, free, upload
                    • #70
                      2 stage colder plugs, and a fresh oil change before the weekends activity...
                      Scott came down in his 3100 turbo swapped chev to work on my tune.... which feels great!!!
                      For some reason the front tires went bald a lot quicker then the rear? lol
                      3pc wheels followed me home yesterday, now I can go back to 245 tires
                      The new tune Scott did really feels good too, hitting 79% duty cycle on those GTP injectors though if I remember right other people running them were around 300whp when maxing them out?
                      • #71
                        Which plugs are you running?
                        • #72
                          AC Delco R42LTS gapped at .035
                          and if anyone's curious I'm at 8psi right now
