Well the cam is wot-techs street/strip cam ground onto a flat tappet cam, specs are
259/265 adv duration
.506"/.506" lift
113 LSA
3.4L/3400 Top End Swap
Probably depends on the cam whether or not stock injectors will be enough. AFAIK all trailblazers with the inline-6 have the 28# injectors.
Well I guess I could give you guys an update. I ordered a custom cam from wot-tech along with the hardened custom length pushrods a couple of months ago and I'm just waiting on my lifters and springs. I was just wondering what you guys think I should run for injectors?
Originally posted by peyo32 View PostJust swapped 3.1 chevy malibu engine to 3.4 engine? So far no problems. Any tips or anybody do it before?
Sent from my iPhone using Tapatalk
Originally posted by caffeine View PostYou'll also need valve springs. Get the comp 26986 springs.
So I think I'm going to go with wot-techs street/strip cam and the custom length pushrods. Can anyone recommend any other things to order that're necessary from wot-tech?
Originally posted by The_Raven View PostWhat? Who told you that the lift "isn't enough for aluminum heads"?
I ran a GMPP cam that was a Crane 260-2 equivalent, which IIRC is similar in specs to the Comp 260H, in my hybrid and it ran well.
Guest repliedWhat? Who told you that the lift "isn't enough for aluminum heads"?
Originally posted by The_Raven View PostThere is no difference, hence being the same. In fact the rods are the same between the 2.8, 3.1/3100 and 3.4/3400 engines. The 3500 uses different rods.
