Originally posted by Robindehood
View Post
3.4L/3400 Top End Swap
Guest replied
Originally posted by caffeine View PostThe rods are the same but the 3400 pistons have a dish. I can't remember if the 3.4 pistons have a dish but if they do its smaller.
Originally posted by The_Raven View PostYes, they are the same between the two engines.
Guest repliedOriginally posted by Robindehood View PostDo you think I'd be able to use the connecting rods off of my 3.4L pistons on 3400 pistons?
Just look at summit or a place like that. Look up the 2000 3400 engine. I havent gotten new springs yet as i was unsure of what cam i was going to run but im going with a set of trickflow ones that will work well and let me reuse the stock seats and retainers.
Any idea where I could find a set of stock pistons? What did you use for your springs and seats? And I'm going to order that pushrod measuring tool for wot-tech to measure mine haha.
Yea you have to change out the pistons to the 3400 ones due to the much smaller combustion chamber on the alum. heads. With the 3.4L iron block pistons youd be up arround 12:1 plus. I cant remember what they say it will be off hand but I know its up there for a pump gas engine.
Ever heard of Deltacams? That's what I have. Currently I have a 260 grind my Camaro and its a good mild cam. Comparable to the 260H from comp. I paid 115 bucks shipped to my door with lifters. Just another choice for ya. The grinds that they sell that are good are the 260 and 272.
I have a 3.1L engine that im doing the hybrid thing on currently but you, just like me, will need to get custom length pushrods. They will cost about 150-200 bucks but its necessary. I still haven't measured mine to confirm the length I need but thanks to another member I have a good idea of the length. Im sure they will be the same as yours.
Hey everyone,
I've been looking into doing this swap for a long time and I finally feel confident enough to give it a shot. This engine will be going into my '95 Camaro with the 3.4L obviously. So far my build plan is:
2000 3400 Upper Plenum
2000 3400 Lower Plenum
2000 3400 Throttle Body
2000 3400 fuel rail + regulator
2000 3400 Fuel lines
3.4 Water Neck (British Car Conversions)
2000 3400 Heads and Valve Covers
Pacesetter Headers
3400 Spark Plugs
Dual wire Temperature Sensor
3.4L Block
I believe that I have to change to the 3400 pistons to run a safe CR, so if anyone can confirm that I'd appreciate it. But just out of curiosity, what would the CR be with the 3.4 Pistons? And other than a junkyard, is there anywhere that sells stock 3400 pistons? As for gaskets I'm not too sure which ones I need so anyone who can help me with that I'd appreciate it as well.
I think I have the tuning part figured out for the most part. I was pointed towards Tunercats who recently came out with support for tuning the 3.4L Pcm in win flash. I feel like a couple of tuning tutorials and I should be able to figure it out.
There's still a few more things I need to decide on and was hoping I could get some help from you guys. For the cam, I've been debating on running the Comp 260H or 252H High Energy Cam, along with 1.6 Comp Rocker Arms with the Hardened Pushrods but I'm not sure if I'd be able to use that with the set-up I described above so any help or guidance you guys can give me is greatly appreciated!
Thanks in advance!
-JohnnyTags: None
