WOT-Tech store layout
  • WOT-Tech store layout
    I am not sure which way to go as far as listing products goes. I need sections for the electronics, and fuel injectors, and other parts, but I also like the ease of use for putting all the 3400 stuff in the 3400 section.
    Any input for organizing things?
    I was thinking something along these lines...
    • Companies that actually supply parts
    • Companies that send the wrong parts
    • Companies that say they are going to supply parts, but never do
      i would LOL, but damn...
      and i think it was working fine before... tried out the newer setup a few minutes ago, also seemed user-friendly.
        I have the heads broken down into sections, but i dont know if i like having so many folders to click on. Really don't know if I should continue or backtrack. I want to be ready for when the new software is finally done. The cylinder heads section is the first one I want to do so I can keep the same theme going for the other areas.
        heads
        manifolds
        valvetrain - springs, pushrods, cams
        air/fuel
        computer/electric
        gaskets/bearings/hardware
        packages
          i like it. i asked in the other thread and sry to go ot, but are the estimated gains for the cams on a stock 3500 similar to the 3400, and would supporting mods increase the gains. how similar is the 1393 grind to the street/strip cam
          MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
            3400 and 3500 will be similar in regards to how the cam acts. The 1393 and the street/strip cam I sell now are close performance wise, but the current cam works with the LS6 yellow springs without coilbind clearance issues on stock heads.
            How are things looking now? I am not sure if I want to list the gaskets in the sections or not just yet. I need a gaskets/bearings section.
              looks good man. i like how everything is broken down by part, then by engine. its alot more user friendly
                Then their's me: Company that supplies the right parts, but sometimes takes forever. :P
                  Got more done. I want to get rid of the engine sections eventually so I need to make sure I have everything in at least 1 other section. I am thinking about removing the "All" section as well.
                    i always use the "all" selection, please don't remove it
                      i like the way its setup now. if only i had money to actaully use anything from the store
