I recently bought a 95 Lumina LS with the lq1. It's been having some running issues where the car will rev up to about 3k by itself and then drop down to about 600rpm and sputter or it will just die on initial start up. So I went and got it scanned (it's OBD 1.5) and it had both quad driver a & b codes come up along with an o2 sensor. So I went and bought a computer for it and put it in. I went a drove it around the block and it ran beautifully plus shifted much better for about 10 minutes and then it went back to doing what it originally was. I messed around with it some more and unplugged the MAF. It ran silky smooth. I went and bought a new MAF, installed it and it ran like hell again as soon as I fired it up (with the new MAF). So at this point I'm at a loss and need some help. I don't know if its a possible vacuum leak somewhere, if it's a wiring issue triggering the quad driver code to come up or maybe a lower intake gasket. The only other bit of knowledge I have on it is that it had about 20 codes pop up that were brake related (my guess is that is caused by a wiring issue somewhere). The brakes are very hard to press and it doesn't stop well at all especially considering the fact that it has a dual piston brake set-up. Checked the brake booster, thought that might be tied in to all this somehow but doesn't look like it. My scanner wont read this car so I'm basically just throwing parts at it blind. Any ideas out there? And sorry for the lengthy paragraph.
-Thanks
-Thanks
