engine main caps and Question(s)
  • engine main caps and Question(s)
    i have started a rebuild and taking heaps of parts to the machine shop but for the life of me i can't find the main caps anymore.
    i have another block laying around for mockup purposes. this one appeared to have spun a rod bearing. can i use the main caps off of this motor in place of mine for the rebuild?
    also i cannot find the nuts that hold on the windage tray, can i just use like the nuts off of the exhaust manifolds for that? or were they special in some kind of way?(doesn't look like they were is memory serves)
    RE: engine main caps and Question(s)
    Loctite the windage tray nuts, that should take care of it. As for the mains, I believe the newer 3400 mains are better quality. They are meant for the other oil pan but even so, they may fit and be better.
      The windage tray nuts I have look identical to the 3X00 exhaust manifold nuts. I have even interchanged them. They are the distorted nuts (don't remember the name for them) that don't back off.
      Marty
      '99 Z-28 - Weekend Driver
      '84 X-11 - Time and Money Pit
      Quote of the week:
      Originally posted by Aaron
        sweet, i have plenty of extra exhaust manifold nuts laying around. the machinist said if i use caps from a different 3.4 dohc it would have to be align bored. or is he just trying to saok me for some dough?
        edit: or was is line bored?
          It will have to be line(align) bored. In a perfect world, you should be able to simply swap them, but the machining process even has tolerances that vary from one block to the next.
