any1 looking for DOHC timing tools
  • Hello guys
    I do not have my cutlass any longer. I will be putting my cam tool on ebay tonight. It one of the original black tools. I bought it about 3 or so years ago, but i cannot find the hold down bolt. other than that is is perfect.
    I will list it as
    "3.4 DOHC Cam Tool Chevy Oldsmobile Pontiac"
    thanks
    steve
    • Hello Again
      Any update on availability of Cam Timing Tool?
      Thanks,
      BMFH
      • Just a note, it cost $35 to have a machinist make me 2 steel bars with bolt holes in them to be able to do stock timing. I just measured what would fit, made a 3-d hand drawn drawing on some graph paper, told him surfaces had to be +/- .003" tolerance to square, and picked them up 2 days later. He did them in his basement with his bridgeport, he's retired. How he got a bridgeport in his basement is beyond me.
        Also, TBH, dropping that motor on the ground, by unbolting the subframe, and jacking the car up, then attaching a degree wheel and doing it with meters wasn't very hard or time consuming, and I know the job was done right, and I know EXACTLY what my advance and retard is.
        • if all you need is stock timing, you can accomplish that with a square piece of keystock with a hole drilled in it.
