Stalls when let up on gas..??
  • Stalls when let up on gas..??
    Just changed the sirpintine belt and coolant. Now when I let up off the gas, the car dies? Any suggestions???
    \'93 Mitsubishi Diamante 3.0 DOHC V6
    \'92 Grand Prix SE 3.4 DOHC V6
    Quick Note
    Did you make sure you routed the belt properly ?
    I mean is it around your alternator, usually when the alternator is shot then the car won't idle.
    Just a suggestion, make sure the belt is routed properly.
    Later
      Ya,the belt looks fine.Now today when I drove it ,it was FINE!!! So maybe it was just one of those things!!!!
        Sounds like an EGR valve sticking. It can be intermittent and usually only starts when it is thoroughly warmed up. But hopefully it is just one of those hickups like you said and not an issue.
        Oh, another thought, if you pulled the battery cable while doing the maintenance and let it sit for a while it can cause some hickups when you start the motor again. Sometimes they fail to remember that they are not operating with a new motor and have to relearn the worn motor settings and all.
        Ross
          Well that would explain it.I did just that.And it still seems to be fine.Now I am working on trying to get her power back, she seems to be a bit tired
