are 96 cams different?
  • are 96 cams different?
    I am running a 93 Z-34 TDC in my fiero, and I need more top end power to really improve my ET and MPH. With the car at just over 2200lbs with me in it I do not need (and cannot use) the low end tq of the engine. I noticed that the 96-97 engine had a higher rpm peak power, and I was wondering if that was only from the redesigned heads/intake/exaust or if the cams had some different specs to them.
    The second question is if the 96 cams are different can I use them in a 93 head, or can I just swap the 96 heads on the 93 block?
    thanx
    Garth
    TDC 87 Fiero GT 5spd
    03 VW GTI VR6 6spd
    87 Pontiac TA GTA 409sbc
    90 RX-7 convertable 383sbc 5 spd
    79 Malibu 355sbc
    The intakes are what really rasie the powerband. The cams are different timing but I do not know what timing that is. You can use 96 cam carriers on a 93 engine as far as I know, but the cam gears need to be swapped since they change those and the belt and the drive pulley in 96.
