total seal ring questions
  • total seal ring questions
    i know you have to have the specs for your pistons but do they have to be YOUR pistons? or do you just need the stock piston specs??? thanks.
    92 Lumina euro 3.4 DOHC 139,XXX miles
    nobody knows the answer??? ben?? any input???
      What pistons are you using? Thats the specs they need to know. Im confused on why you clarified "your" pistons. your pistons will be the same as my pistons if we both have the same part number.
        well what i meant is if they need you to measure your pistons because all pistons cant be the exact same, well stock ones at least. i know if i go with the h pistons i can get the info from them.
          They are all stock replacement pistons unless you get custom pistons made. Therefore you just need to know what year. They should have the 3.4 DOHC piston specs already.
            well i forget who but they said youd need to measure your pistons and have them made to that size, thats why i asked. thanks alot though it really helped.
