xoneliths Track info
  • xoneliths Track info
    New pb:
    13.991 @ 99.13 MPH
    All Motor 2001 GA GT1
    HPTuners.com
    MilzyMotorsports.com
    GrandsOntario.com
    do u use slicks? any new mods? or did u just drop ur 60ft?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
      I got 13.786 @ 103.47, shitty sate of tune and a plugged cat... Stock 3 year old clutch too.
        add me to the list.....15.74@87
        1995 Monte Carlo Z34
          No slicks, stock weight.
          Nothin' new.
          I think the cooler weather is helping me. My 60' is better, but I have run quite a few 2.1's, just not 2.12 I've also been workin' on my tune, but I found that my injector duty cycle is at 92% at 6200-6400 rpm. I don't want to try and add any fuel and timing until I upgrade these.
          I'm waiting for an engine mount which I hope to get soon. I'm thinking some of the KR i'm getting is from the amount of movement I have under the hood (we'll see). If it is, I can up the timing again I'm still pretty much at stock timing.
          HPTuners.com
          GrandsOntario.com
            I'll add anyone who PMs, or E Mails a time slip. Gotta be fair to all.
              Damn... gotta get back to teh track then!
              3.1L \'88 Camaro - 16G @ 9.5psi
              222/291 @ wheels
              T61 on the way!
                do u have a stock bottom end?
                  If you are asking me, then yes. Eventually I plan to build it up. My compression ratio right now is around 10:1 due to the headwork, but I hope to increase it slightly (unless I go turbo... not sure what I'm doing yet...LOL)
                  I've been told the bottom end should hold the tiny bit of power I've got. We'll see
                  HPTuners.com
                  GrandsOntario.com
                    u don't want to go turbo with that cam and headers that you have on.
                      Some say there is too much overlap, but I'm thinking, it will spool the turbo quicker. My buddy has a big cam in a GTP and the T60 he bolted on, spools up nicely!!
                      I have to do some more research, but I'll figure something out
                      HPTuners.com
                      GrandsOntario.com
                        why are there 2 of these threads? One by bszopi and one by redandblack? Which one is primary?
                        HPTuners.com
                        GrandsOntario.com
                          Brad was the moderator of this forum, but I stole it from him. :P
                          Actually this forum was my idea, and I'm happy to be able to moderate it. He was nice enough to let me. I wasn't going to delete his thread, but he did already. All the info was transferred. Thanx Brad.
                          And with that, I am going to split this thread to let you have your own, to tell your tech info.
                            LOL... cool, but you can delete my posts. I wont' be offended.
                            HPTuners.com
                            GrandsOntario.com
                              How does 203 hp at the wheels = 13.99? Have you done a lot of weight reduction? Trans mods? I just can't figure it out when 218 at the wheels in a Z34 5 speed = 14.6 and the weight should be damn close between the 2. Gearing should at least offset that since its close ratio for the 284.
