97 Monte Carlo 3100 motor part out
  • 97 Monte Carlo 3100 motor part out
    Motor has a broken cam shaft and 132k miles... Ask about anything not listed... You pay shipping... Its easiest to contact me by cell phone and I am in Norfolk NE
    419-376-4073
    Upper intake - 30
    Lower Intake - 30
    Heads - 50
    Willing to trade for 3400 heads
    Transmission from 96 Grand Prix with 184k miles... Serviced Regularly, Has broken piece below the left dowl pin... I can have it welded and it does not affect performance... 50 picked up
    Alex (Big Al) Walker
    someday GM will pull its collective heads out of their collective asses and listen to us... or go bankru... oops.
    Seriously, I'll take what's left of the cam... I have an idea that I need a model cam for.
      Ok, I dont have anything torn off the motor right now so I will be a bit, hope your ok with that?
        I need the drivers side dogbone bracket and bolts (upper torque strut bracket) off the engine.
        I don't have a pic, but if you're not sure what I am refering to I can find one. If you have the dogbone as well and it is in decent conditon I'll take that too. Both dogbones if you have them.
        1994 Corvette
        LT1/ZF6
        2006 Dodge Dakota 4x4
        3.7/42RLE
          Yep. I need the timing cover end (with the CMP reluctor ring), if/when you can get it out. I'm going to assume you're keeping the ECM, right?
            I have at least one of the full mounts (all parts between the frame rail and the engine brackets) in my junk box in the garage. Guess the guy didn't understand that I didn't need them for my 3x00 swap into RWD...
              I lol'd at that. That's funny!
                What's even funnier was that I drove my RWD car to pick up the parts... Probably should have just left the mounts, but, eh, if someone needs them, I can sell them for cheap. If not, that's what metal recycling's for.
                  Sell me the valve spring retainers off the head?
                    I dont have the mounts on the engine... I left them in the car and reused them... I do however have this one from one of my previous part outs... I know I have more and I will have to find them
                    If that looks right, Ill send it out and will find others also
                    Alright, Ill let you know when I tear into it... Also, Wiring harness was sold complete with ECM (It was a 96 GP wiring harness)
                    Will do... In fact, It might be easier to send you the whole head, Let me know if your ok with that
                      Ah. I was assuming you had a stock Monte ECM in there anyways, and I can't use OBDII stuff, so no biggie.
                        Hey BigAl, is the dogbone in that mount a dohc dogbone or a 3x00 one? Can anyone verify that the left and right radiator side brackets are the same on a W car? I imagine they are. If it is a 3x00 dogbone how much for the bracket and db?
                        1994 Corvette
                        LT1/ZF6
                        3.7/42RLE
                          I honestly dont remember which one its from... Ill send it and the other one (if i can find it) for $25 shipped
                            I may have a line on the parts I am looking for but if not I will take what you have for the price posted... can I let you know in a few days?
                            Thanks,
                            John
                            1994 Corvette
                            LT1/ZF6
                            3.7/42RLE
                              That's fine... I actually have someone interested in the complete motor and if he wants it then I will sell it complete... Ill post an update in less than 24 hours
