$A1 Tunerpro XDF
  • #31
    Well here it is... $A1 Full Ver 0.5.xdf
    I put in some more time this morning, I'm about 30% done the constants now.
    I'm sure there's a few errors, so if you notice anything wrong, let me know, and I'll fix it for the complete Version 1.0.
    Just a couple notes, I'm trying to get everything under it's proper category, this makes things much easier to find.
    Also, I put the assembly item name, and what everything does (as copied from 727_730_A1.doc), in the description field. This is so you can use the Item Finder and search using the Description if you have to. This might help if you can't find a certain item, or the title isn't as descriptive as it should be.
    • #32
      WOW! Neat stuff! Great 1/2 job!
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • #33
        I'll give myself a 1/2 pat on the back lmao.
        • #34
          Where it says BPW as a function of airflow under flags, it needs to say idle in front of it:P Great layout though
          • #35
            that's why i couldn't adjust the idle AFR.
            Andy
            • #36
              Thanks, but I haven't touched any of the flags yet. That was in the original XDF that I started with. Keep the suggestions coming.
              • #37
                How are things going so far?
                Andy
                • #38
                  How about now???
                  Andy
                  • #39
                    Hmm, I haven't had a chance to work on it lately.
                    A minor bathroom leak has turned into a full scale renovation, so that's consuming a lot of my time (and money, booo!) lately.
                    I did a bunch of work since Version 0.5, maybe I'll release Version 0.6.
                    • #40
                      yep, those little fixes usually turn into a full scale renovation, especially guys like us. lol
                      that'd be cool to see the 0.6!
                      Andy
                      • #41
                        DUDE! your killing me here!!! what's up?
                        Andy
                        • #42
                          anything new? im interested in this xdf as well
                          ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
                          87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
                          • #43
                            he's been too busy to sit down and work this out. he still plans on doing it, but just not for a while yet. unfortunately.
                            Andy
