1998 monte 3100 to 3.4
  • 1998 monte 3100 to 3.4
    I have a 1998 monte with the 3100 in it. I'm looking at getting a 3.4 DOHC from a 1996 monte carlo that has 88,000 miles on it. What all do I need for it to work. If the stock ecu will work but not as well as the 3.4's that will be fine for me now. I know the tranny is the same but what about wiring harness, fuel lines, vaccum lines ect...
    also, the 3100 in the 98 is from a 96 monte.
      Hi,
      Look my previous thread in this forum (03-28.2011):
      "3100/3.4 DOHC Swap: Part List"
      Denis
        dohc is junk.
          Originally posted by lrosstal View Post
          dohc is junk.
          How so?
          -Matt
            dohc is junk.
            If you joined to say that, consider yourself banned.
              LOL
              -Matt
                Originally posted by mrl390 View Post
                How so?
                It's too complicated for the simple minded, that's all.
                  It isn't a swap I would recommend, but the 3.4 DOHC has a ton of potential.
                    It just lacks an aftermarket :/
                    Turbos help with that though, lol. The DOHC reacts well to boost, too.
                      I was waiting to hear him say something about the timing belt breaking after running it for 120k miles without changing it, or it running bad because he never changed the rear spark plugs because they are too hard to get too, or something along those lines. lol. The usual kind of neglect that causes people to dislike the DOHC.
                      -Matt
                        QFT
                        If you can't take care of a car, don't expect it to take care of you, lol. It's not rocket science.
                          AND these 3x00 motors were designed to easily go 400,000 miles plus IF they are allowed to warm up some before people dog it. People complain about piston slap not realizing it is a good thing, sort of.
                          Plus the 60°v6 design angle versus the 90°v6 has a perfect division of 60° per cylinder. Meaning no heavy balancers needed on the crank. Also making it more compact saving valuable space in the bay.
                          I consider these 3x00 engines a stroke of genius (mixed with a few instances of GM insanity)
                            You forgot smoother running which would help longevity with proper care.
