Where can I get tubular rear control arms?
  • Where can I get tubular rear control arms?
    Thanks!
    Matt
    '93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
    I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
    camaromanmatt@yahoo.com
    gm makes a set for the 97+ Grand Prix that fits your car as well. gmpartsdirect.com is where I got mine but I have forgotten the part number.
      Just the factory 97+ will directly fit in? And they are tubular?
        97+ are not tubular stock. The GM p/n for tubular is 12498649. Get them at www.gmpartsdirect.com
        Ben, they fit the older W bodies? Cool!
          yeah they fit gen1 and 2 cars. i had them on my 93 Z34. they went with it to the junkyard because the kid that put them on was a hack and overtorqued the bolts so much they would not come out with 5 foot cheater on my breaker bar.
          i've seen enough bent/rusted out/broken stock rear trailing arms to say the gmpp tubular arms are a MUST for ALL w-bodies regardless of whether you are looking for performance or just daily driving.
            That's a trailing arm, not a control arm
            Ya I've owned 2 GP's (90 and a 91) and BOTH have the stupid assed same issue: rusting out, and rear shock towers blowing thru Well, my '91 hasn't blown thru YET, but it's DAMN CLOSE.
              The control arms from BMR will fit. I have them with the GMPP trailing arms on my Monte.
              Tim
              325 whp 350 lb-ft
                I got the GMPP TA's and they are great for the price....MUCH better than stock.
                  Ive got the BMR trailing arms on mine:
                  ( stock vs BMR )
                  But then again it depends on how much you wanna spend...
                  3400/Getrag 284 5spd
                  350/NV3500 5spd
                  2014 Chevrolet Malibu LS
                    Tim
                    325 whp 350 lb-ft
                      The GM trailing arms are the same ones that come on the Monte Carlo with HD Suspension. I work at a GM dealer and for the record it's much cheaper getting the GM Performance Parts kit #12498649 than getting them seperate. And it makes a big difference in handling too!!
                        to bad the n-body guys didn't get anything like that
                          What is the part number on those Control Arms from BMR that run along the leaf spring? Those look great. How much of a difference did you see with those? ( the Trailing arms & the Control Arms?)
                          1991 Grand Prix STE
                          3.4 DOHC
                          1 of 792 Produced
                          Extensive Mods Done
                          1991 Lumina Z34
                          3.4 DOHC
                          Getrag 284 5spd
                          1 of 30
                            Oh, yeah control arms. I didn't catch that. I didn't know tubular ones were out there. Is BMR the only place to get em?
                              The biggest difference was because of the bushings. They're much stiffer in all of the components. Much less squirming as the car loads up. With 16" wheels it wasn't as noticeable as with the 18's.
                              Tim
                              325 whp 350 lb-ft
