62mm Throttle body
  • 62mm Throttle body
    Ok,so I looked at a few threads about putting a bigger throttle body on my project car.Saw one sold by Milzy motorsports.Will a stock TPS swap onto these after market throttle bodies?
    The TCE? Yes it will. As will the IAC valve.
    Oops, that would only be for the 3100 or 3400. Not sure on 3500. If I remember right there is no way on the 3.1 TPS. The wiring should be the same.
    Sorry, have not been following your build. Just found out that you have a 3.1 from checking the "what's new".
    Grand Prix trans with 3.33FDR
      I have been working this project a long time!Like 13 years! I swapped a 3.1lt into a Porsche 914. I have the 1991 3.1 block,1994 3100 heads and 2000 3400 upper and lower intake setup.If you look into the swap area I think the thread is called 914 3.1 or something.
        It could be something I've posted in at one time and just forgot about. Forgetting a lot these days. Then projects come and go too, kind of hard to keep up.
          LX5 65mm TB can be done for under $100, $55 adapter from WOT-Tech and a visit to a local junkyard for a LX5 TB(99-02 Oldsmobile Intrigues and 01-02 Oldsmobile Auroras)
          I'm running one on my 3500 and love it, 65mm LX5 TB on top and stock 3400 TB on the bottom which i believe is 56mm?
            With the TCE you need to have the upper ported to match the TB(then it's a bolt on with no adapter). WOT-Tech will do that as will Milzy. Would cost a lot more than the above option, but you start with a new TB. Then you can swap your stock linkage into the TCE. LOL guess it's not a totally new TB after all.
