When my machinist tanked my 2.8 block he found an oil pressure valve in the block behind the oil filter plate. He told me I didn't need it as the plate already had one in it, he showed it to me.
When I was installing my engine I noticed that the oil filter had lost all it's oil after priming. It did set for a long time. I turned the oil pump by hand and there was plenty of oil coming out of the oil hole. However on first start up I had alot of lifter noise, everything new, and now in the mornings I still get alot of lifter noise. The oil pressure is 60+ lbs. I wonder if I need to put that valve back in the block. Is the lack of it letting the oil filter bleed out?
