3500 fiero failure
  • 3500 fiero failure
    dunno what it was yet, ill find out in the morning....
    its making a lot of noise on cyl 2 4 6 side. sounds like a rocker arm smashing into the intake port. gets louder with rpm. oil pressure is around 65-70 psi hot.
    any guesses? ill know about 8 am tomorrow. im hoping i didnt drop a valve or something that would ruin the head, cyl or pistons
    2012 Chevy Sonic Turbo 6spd
    pull the valve cover and see if you broke a rocker stud...
      Nooooo. WTF? Hope it's something small.
      My turbo didn't last long, but it was a stupid mistake on my part. Hope that it's not as bad as expected. Hate it when a lot of work goes into a failure
        im sure its nothing extreme. ill know in the morn.
        im thinking its a rocker arm or maybe a valve.
          Collapsed lifters with bent pushrods with the added hint of smashed valves, MAYBE. No other noises?
            I know a couple of times now, I have had a rocker come loose. I know one of the times had to do with my sister-in-law, the other time, I think it just was not seated right and worked loose. The second one, it was fine when I started it, but 2 days later was making noise.
            Taylor
            1998 Lincoln Mark VIII
              hmm, maybe thats it. i had to take my brother to work, so ill be out to my car in just a few mins...wish me luck
                Where the rocker arm bolts torqued with a torque wrench or guestimated by feel? They shouldn't come loose if torqued properly.
                  rocker arms were fine. oil smelled like fuel. it was knocking on the botom end. i changed the oil (it flowed like water when the oil was 40*!!) and threw a rod on the way home. its dead. time to see if all pro used auto parts lives up to thier 3 year warranty.
                  the engine sounds like a coffee cann full of ball bearing in a paint shaker. its fucked.
                  and not to mention i have $97 to my name. im so bummed. im gonna go take a shower and go to bed. see you guys later
                    that blows if that parts store dont give a u new motor throw a brick threw window!
                    1997 Chevrolet Camaro 30th Anniversary 5Speed.
                    3800 V6 (i know its not a 60degree)
                    stock for now
                    1993 Special Edtion/GTP
                    3.4 DOHC V6 LQ1 SOLD!
                    CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
                    180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
                    VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
                      they are 2000 miles away....i cant throw that far
                        Shit. I hope they fix you up.
                          Not from me
                          I wonder what failed? Fuel in your oil, hmmm...
                            it was running rich as hell....but im thinking leaking injectors? hell i dont know. i wont know for a while.
                            good news is that im getting a trailblazer this weekend so i can make it to work n back. only 61K miles and $9400 leather 4wd, loaded. im putting the fiero in the driveway till i get another 3500. i doubt allpro is going to live up to thier guarentee after what i went through with the cracked intakes. but im going to push em.
                            im going to take my time on this engine. maybe a wild cam? supercharger? turbo?
                            the entire ride home from the shop the oil pressure was around 45 and the coolant temp was around 225....funny stuff.
                              Mine came from the same place so I guess we'll see what their ratio of engines to grenades is soon enough!
