another windage tray???
  • another windage tray???
    What exactly do I need to use a 3400 tray on my 3.4 iron head?
    The tray (modified to fit my 4x4 oil pan from my understanding)
    the correct main studs.
    the nuts that hold them on.
    Am I correct on this?
    Anybody have a clue on the correct studs I need?
    87 3.4 4x4 blazer
    you just need 3400 main studs.
    alternately, the 3.4DOHC windage tray is a direct bolt-on to the genII(and maybe GenI) motors, using the 3.4DOHC main studs as well.,
    Cammed 3400 --> 224whp 210wtq
    Cammed 3500 --> ???
    1 of 5 3500 J-Bodies
      Yes it is. I tried the DOHC Pan and it fits perfect on a Gen I block with the DOHC main studs. However the 4X4 pan will need some massaging in oder to fit. A bit of heat from a propane torch and a rubber mallet will do the trick. Modify the pan not the tray
          I knew there was something up with the 3x00 windage tray but didn't remember the details. Glad we have an article for that!
            I knew I've seen that before and done a search and came up with nothing. Thanks.
            87 3.4 4x4 blazer
