i had been researching and setting ,yself up for building a hybrid for my s10. but this coming saturday, im picking up a supposedly good running (cant hear it run due to no key and the VATS. any way to bypass that?)3.4 out of a 94 fireburd. comes with wiring, computer, accessories, cats, everything that is attached to the motor exce[t the trans. 100 bucks. even out of a five speed, so the swap is easier.
im planning on just cleaning it up, maybe a ring and bearing job, baffling the oil pan and puttig a windage tray in it, and putting it in.
ut then i look at my dremel tool and carbide bits, and think about porting the eads, intake, and TB. and if im going to do that, may as well put a bigger cam and mill the heads to bump the compression
anyway, the firebird is setup with obd 1.5. is that tunable? also, will the VATS systm that keeps me from hearing it run cause me to not be able to get it to run wen swapped?
thanks
Michael
thanks
Michael
