alot of the "sloppy mechanics" (the guys who by a 4.8/5.3/6.0 and a big ebay turbo, and, well,, send it) say not to even look at cab bearings, ever. but you're also building an engine that you hope to run all our for 24 hrs. I will say, that short of roller cam bearings, there is no reason to get fancy ones. just make sure you get a quality brand.
Road Race Engine Build
I was going to do that but I learned how to use a new toy at work and the bearing spacers aren't going to be very rebuild friendly. Also, I redid the math and I'll be at 0.533" lift with a lot to too much valve spring. So I shaved 0.055" off of one side of Teflon coated SBC bearings and will sink those in the spacers tomorrow. Then I can check piston to valve clearance and get the crank off to be balanced. I was hoping the piston weights were or could be made close but the LZ pistons are 100g heavier than the LX9 pistons. I have the Federal Mogul version with the thinner ring package. The Mahle pistons are different.
Got all the cam bearings/spacers in and the cam spins nice and free like it should.
Piston to valve clearance is more than adequate for 0.533". Someone on that Fiero forum said these engines were safe up to 0.545" valve lift and that seems to be in right ballpark. I should have gotten an exact number for clearance but I was more than safe and moved on.
I did a little playing with push-rod length and it looks like I need an extra 0.075" on the intake and 0.085" on the exhaust. Anyone else find that the exhaust push-rod needed more length than the intake? I wouldn't have expected this but maybe this is to compensate for extra heat.
I've never measured them, the new 3500 I'm about to be working on will be carefully measured though. that being said, if you took careful measurements, and more than one came up longer, I wouldn't worry about it. I am worried about piston to valve clearance in mine, my cam runs about .576" lift, so I need to be careful for sure..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
My low mileage LX9 with stock timing chain, mild springs, and 0.504" lift had slight valve impressions on the pistons so more than that and you are very likely to have clearance problems on an LX9. I think guys with high mileage stock motors were having the same witness marks too. Hate to be the bearer of bad news but it's easier on the schedule to know you might have to cut valve pockets early that be surprised in my mind.
Originally posted by neophile_17 View PostMy low mileage LX9 with stock timing chain, mild springs, and 0.504" lift had slight valve impressions on the pistons so more than that and you are very likely to have clearance problems on an LX9. I think guys with high mileage stock motors were having the same witness marks too. Hate to be the bearer of bad news but it's easier on the schedule to know you might have to cut valve pockets early that be surprised in my mind.1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
Originally posted by 1QUICKHATCH View PostWhat where you spinning it to? And what springs did you use?
Something to note. If you use the LZ timing chain tensioner with a pre-99 timing chain you'll have to message the tensioner a little. Otherwise the back of the timing chain pins rub on the tensioner backing plate. A couple of light taps should do it.
I measured the stock pushrods in the LZ and then the LA1 pushrods I had just as a second data point. The LZ pushrods are longer than all the spec sheets that I have seen for the LZ. The spec sheet states 5.750" and 6.000"You do not have permission to view this gallery.
This gallery has 1 photos.
This is good to know, thank you!
