Valve job info on the "how to do head work at home"
  • Valve job info on the "how to do head work at home"
    Anything to add for head work? Also, I need to add the valve job info. I know the valve seat angle is 45 degrees. I have a book that has some info but I am making all posts here for updates.
    Good Stuff!
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      Here is an interesting article I found when doing some searching on VE...
      There are 2 more in the series, but I have yet to look at them.
        "Many novice porters make the head opening larger on the pushrod side of the port. This allows the intake charge to expand and then contract to clear the pushrod, exacerbating the problem."
        Um, pushrods in the ports...im so very very confused.
          Pushrods help push the air in the engine, kinda like a turbo or S/C, lol. That's why they are called pushrods silly!
            ben on SBC's the pushrods sit so close to the intake ports that the castings have a bend in area the pushrod pinch area, where the intake port closes in due to the way the heads are cast..
            thats what they are refering to.
            Colin
              strange, thanks for clearing that up.
