4T65E
  • Other Mounting Options
  • 4T65E and 4T65E HD (99+) N-Body Swap
    Other Mounting Options:
    Front Mount:
    This is the front mount off a 2008 3.9L G6. GM Part # 15299171 List Price $49.01
    The 3.9L G6 4T65E transmission has a special mounting boss on the case, therefore you will need to make a bracket to support the third bolt hole on the bell housing side of the mount. Note: The bracket in the pictured was for mock-up purposes. The actual bracket is made from thicker material.
    Side Mount:
    In keeping with the design of the concept car, I had a machinist CNC machine an aluminum tab that can be welded onto the stock production mount. Note: if there is any interest, I can have more of these weld on tabs made for a cost of $45.
    Rear Mount:
    Still in the design process, however cardboard templates should provide a good design template that can be copied onto steel. The goal is to create a rear mount that will work on both the 4T65E & 4T65E HD models.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • 4 Speed Automatic Transaxle Info
      by robertisaar
      The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
      10-08-2010, 02:48 PM
      by onefastV6
      So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
      09-20-2010, 09:36 PM
    • 4T4x-E Mechanical Specifications Information
      by bszopi
      4T40-E/4T45-E Automatic Transaxle Unit Repair
      NOTE: Click on images to see a full-size view.
      Fastener Tightening Specifications
      End Play Specifications
      Reverse Clutch Backing Plate Specifications
      On-Vehicle
      General Specifications
      Range Reference
      Shift Solenoid Va...
      08-18-2010, 09:25 PM
    • 4T65E Hardened 4th hub and solenoid upgrade
      by Tbay99Venture
      INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
      07-24-2010, 10:59 PM
