I know why you were asking, but don't forget his son works with him. The crank triggers would be a repeat job, so that could be taken care of by a machine operator. The DRTC's are a different story since not only are they custom, he was using outside sources. It also has me intrigued, just was making guesses though.
3500 in a P'up
Maybe I should get a crank trigger while I can, so I can use this LX9 someday when I finally have somewhere to put it.'98 Volvo V90 - Ford 5.0 swap in progress
Re. the crank pulley; I tried the third time to pull it on with a bolt - goes about 1/2 way. I measured the OD of the shaft - looks like 31.7mm. Measured the crank pulley ID, about 31.5mm. I am going to take the pulley to a machine shop and have them check to see if the bore is true/linear or has a taper in it. It needs to have about .010" taken out to fit.
I have located all the sensors and their connectors and wires on the LX9 to marry it to the '94 Cav harness. Now to tidy up the wiring, eliminating the non-engine/ECM wiring. Good winter project!
It's a press fit, I wouldn't have it machined unless your mixing and matching parts, or if this is some aftermarket HB that was never on an engine before.Last edited by 3400-95-Modified; 01-20-2014, 04:32 PM.
Hi All,
Back in the game.... My copy of the wiring diagram for the ECU appears to be missing info on the far right side when printed. Do all the connections from the ECU (usually black or brown) that go to a 'dot' mean ground?
I cannot find the original link from Z24. If you have it, please forward. BTW, I was able to get the crank pulley and sensor ring and CPS all on and lined up.
I have collected many diagrams, which one are you looking at? What vehicle and/or ECU is it for?'98 Volvo V90 - Ford 5.0 swap in progress
