Plans for L32/3X00 Hybrid
  • tkoforpresident
    replied
    Mine is more of an observation than an opinion lol. I usually just do what you guys tell me to do if there is any doubt.
    replied
    and this is why multiple opinions are a good thing.
  • tkoforpresident
    replied
    Most cts that i buy seem to come with teflon tape on the threads
    replied
    i would be worried about the RTV/tape insulating the sensor and not allowing a good electrical reading... i think.
  • tkoforpresident
    replied
    Sorry I'm an idiot its definitely 3/8 ". The 1/2" -3/8 reducer threaded in perfectly. Should i use teflon tape or some kind of rtv to seal the threads? Things are working out great. Im very happy
  • tkoforpresident
    replied
    Just bought a 1/2"-3/8" NPT reducer bushing.
    I got brass as to reduce oxidation (or so I was told haha)
    So it looks like I'll be able to use my old CTS (single wire, located in the drivers side head, used for dash guage) in that location as long as it's 3/8" NPT like we are thinking.
    there IS one problem however. Just thinking back to my memory... I believe the OTHER bung located in the thermostat housing (stock 3500 CTS location) is 1/4", or at least it looks that small.... Which has me worried since I don't think any of my stock sensors are 1/4"... that's awfully small.
  • tkoforpresident
    replied
    Cool thanks. I'm gonna clean it up and paint it.
  • CNCguy
    replied
    Looks good Max and should work fine.
  • TechRod
    replied
    Hopefully that'll do the trick for ya.
  • tkoforpresident
    replied
    So I got to about 7-8 threads left on the tap. That good enough for you guys?
  • tkoforpresident
    replied
    OK, I'll keep working it in.
    Thanks guys.
  • CNCguy
    replied
    Max,
    You will need to go to 7 threads from the back for proper fit. If it gets tight while cranking it in, back the tap back out 1/2 turn. This will break the chip and make the tap easier to turn in.
  • TechRod
    replied
    Looks like you need to keep working it, the more times you run the tap in and out the cleaner/smoother it will get.
  • tkoforpresident
    replied
    Here is a pic of the thread that I tapped into the LIM.
    I think I ended up with about 9-10 threads left on the tap. Is that good enough? It was getting very difficult to hold the intake and turn the tap towards the end and I was turning so hard that I felt like I was going to break something. So I stopped there just to be safe.
    How can I find out if it's good enough? Should I buy the 1/2"-3/8" reducer and see how it feels threading it in?
    Let me know what you think, thanks.
    Btw Marc, thanks for the tips regarding the wd-40 and 6 point socket. I used them both.
  • tkoforpresident
    replied
    going over right now to work on the intakes....
