i'm new sort of new to the site and would like to know lf a 3500 or a 3400 top end buildup is a good idea, and if so what would i need how much would it cost and what can i buy from you?
3500 top end
The vacuum issues aren't that big of a deal with vacuum line and T fittings. Phil did a write up for what he did though we have to weld up the intake manifold due to the amount of metal I removed to clear the 3400 FPR. Making it so less has to be removed is on my todo list right now. Its actually easier to use the 3500 heads and lower with the 3400 plenum. You get most of the gains from that without any of the real issues with the swap that I am dealing with right now.Ben
http://60degreev6.com/showthread.php?t=32908
His stock PCM was giving him issues actually with the stock 3400 so I don't know how much difference there will be for someone else. Id definetly want a way to tune that top end swap though. Once you can tune, you never want to go without the ability again
The 3900 has wider bore spacing so the top end won't bolt up to the 3400.Ben
