In my effort to demod the Grand Prix I removed the underdrive aluminum crank pulley and reinstalled the stock steel unit.
When I installed the stock pulley I noticed how much thicker the base of the aluminum pulley was and that I had used longer aftermarket bolts to install it to make up for the difference. The stock bolts are long gone but I found some that looked to be about the right length (shorter) for the steel pulley and went on my way installing.
Now, when I go to start the engine the starter engages the flywheel and loads up but it cannot even budge the crank at all. I knew the battery was weak and thought that to be the issue so I tried to pop start it and the wheels locked up solid when I dumped the clutch. Even installed a new battery and still it cannot turn the motor. What went wrong here?
My only theory is that if the bolts I used (the three surrounding not the centerbolt) were just a bit too long would they go clear through the harmonic balancer and come into contact with the timing cover? I used an impact gun to secure the bolts (including center bolt), can that be the issue?
Any thoughts?
Any thoughts?
